Conn ST-11 Strobotuner Mod Help - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 24th September 2012, 10:02 PM   #21
Enzo is offline Enzo  United States
The clock only needs to be stable on a short term basis. Every time you use the unit, you start by calibrating it to the mains frequency. There is a setting on the front panel just for that. And by the time it is divided down for the motors, a few hertz drift would not be noticed. SO unlike some video source that must sync up to the world, they could get away with a "poorly designed" clock. These little units worked quite well.
Old 24th September 2012, 10:21 PM   #22
labjr is offline labjr  United States
The units did work well. I still have several of them. Would be nice though if they had a position on the frequency adjust dial that said "locked" or something like that so one could use it for concert pitch only and not have to fuss with calibrating at all.
Old 23rd February 2014, 08:28 AM   #23
I have CONN Strobotuner ST-11, and today its motor stopped spinning (lights & pilot LED are on and +50V of motor power transistors is OK, though voltage to the motor is only 1.4 volt). Do you have some troubleshooting documents, or any suggestions?
Thanks,
SW
Old 10th February 2016, 09:03 PM   #24
cos000 is offline cos000  Italy
Hello to everyone.
I have a ST-11 bought from USA. I live in Italy and I have 230V 50Hz.
I've understood how to mod the tuner for 240V but my problem remain the 50Hz.
Does anyone know how to mod it in order to use calibration with 50Hz (transform it into a ST-12?
Thanks so much
Old 21st March 2016, 12:36 PM   #25
Originally Posted by cos000 View Post
Hello to everyone.
Thanks so much
Hello
No one can help me into find what do I have to change?
Old 21st March 2016, 08:36 PM   #26
Do you have a schematic? Mine are miles away. Contact Peterson and ask if they have any such information. Last time I checked (a while ago) Peterson web site has a forum, and a section there where they discuss old Conn tuners. (Peterson bought the Conn assets when Conn went under.)
Old 21st March 2016, 10:57 PM   #27
Hello
Thanks for the reply.
I have schematics of ST-11 which don't include 50Hz mod.
I know about that forum but it seems they have deleted it... I can't find it anymore...
Nevertheless, after one hour spent on calculations and thoughts, I think I solved it also with the help of post #17 of this thread.
I have to write it down and then I'll post my solution.
Seeking schematic for Conn organ amp Captn Dave Instruments and Amps 11 20th November 2016 08:46 PM
Conn organ conversion to amp nuvo Instruments and Amps 33 7th September 2016 11:01 PM
Conn Caprice organ ThSpeakerDude88 Tubes / Valves 31 12th December 2015 09:27 AM
conn organ amp help jazzgene Instruments and Amps 0 11th April 2006 05:51 PM
Copyright 1999-2017 diyAudio
