Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 20th November 2008, 10:14 PM   #1
Default Help on guitar jack soldering?
Sorry for being a complete useless but.....
Can somebody please put me right on soldering a 1/4 jack socket on my guitar project.
Wires from the switches to the jack are TWO - one red (inner white with outer braiding) / one yellow.
I've soldered the yellow to the outer connection on the jack with the red (inner white) to the inner jack connection leaving the braiding cut off and NOT connected to anything.
When plugging into the amp I get a horrible buzzing which goes away to silent when I either touch the jack holder or the lead connection with my hand.
Otherwise the guitar sound plays through the amp no bother!
Just this horrible buzzing - not too loud but definitely there!
Help please - I'm slightly competent but definitely no "boffin"!
Old 24th November 2008, 01:11 AM   #2
Default 43 viewers and NO HELP!!!!!!!! USELESS SOLDERER
Very disappointed I have had no replies with solution to my problem re - USELESS SOLDERER.
To date 43 viewers of this post and NO replies!!!!....C'mon guys!
I joined this Forum expecting some life out there!!!!!!
Looks like i may have to look elsewhere.
Old 24th November 2008, 08:19 AM   #3
Bone is offline Bone  United Kingdom
If you gave us more information it would help. Like type of amplifier, drawing of connections etc.
No one could diagnose your problem from what you have told us as all amps vary.
Tony.
Old 25th November 2008, 06:28 AM   #4
wxn is offline wxn  Lithuania
wxn's Avatar
ALL buzz problems can be solved by carefully shielding all cavities, using shielded wires, making proper ground planes etc. Google is your friend
Nothing is as simple as it seems
Old 28th November 2008, 02:02 PM   #5
vglaso is offline vglaso  United States
Default grounding issue
you may have already solved your problem... (am not sure what pick-ups /switching you've done, but fact you can touch strings...and buzz quits? Try taking shielding (meaning the wrap around wire) to ground...(or) one of (2) wires to ground.... see what happens.
Old 30th November 2008, 08:19 PM   #6
"leaving the braiding cut off and NOT connected to anything" -
that'll cause the buzz, it needs to be connected to the earth (outer) connection of the jack.
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 28th December 2010, 10:19 AM   #7
here also same problem.. please help ma circuit is ruby amp.
Old 28th December 2010, 11:33 AM   #8
chris661's Avatar
You must remember that we're all here by choice. We don't have to reply. Not all of us log in here every day, and those of us that do, don't always check the entire forum.
Soldering the braiding to the biggest connection of the plug will sort you out.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 28th December 2010, 06:58 PM   #9
indianajo's Avatar
Default HUM WARS
You want a blow by blow of a hum war look at the last post of this thread Improving a "Disco mixer" to mid-fi performance
Took me over 7 months to figure out. There is no one solution to eliminating hum. Fresh & adequate power supply capacitors, solid connections both input sides, cable shield connected to case only at one end, metal box grounded to the wall safety ground at only one point, steel box around power transformer or transformer mounted outside the amplifier case, power supply regulator, local hash bypass caps, blah, blah blah. The thread doesn't even talk about how many times I broke the solder joint on the input connectors. One tip- don't buy SPC21418 XLR connectors, the housing wiggles too much and bumps the connections.
Some of the issues on proper input cable design are covered in this thread Phono MC/MM who is running balanced?
One reason guitar effect kits usually suggest a 9V battery as power is they don't want get into the above issues about power line hum, for a $29 kit. Even if you have to buy a $3 battery every week.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 23rd April 2009 11:43 PM
2 Mono Jack to Female Stereo Jack JellyMan Everything Else 2 27th May 2008 03:39 PM
making dual mono jack from single mono jack dubmunkey Analog Line Level 2 12th October 2006 02:16 PM
Thanks Jack and RIP Nuuk Everything Else 11 24th June 2005 10:46 AM
guitar amp input jack help BelieveInKarma Tubes / Valves 16 30th December 2003 04:44 PM
Page generated in 0.09145 seconds (86.67% PHP - 13.33% MySQL) with 10 queries
