| Instruments and Amps Everything that makes music, Especially including instrument amps. |
what are the best germanium transistor npn and pnp ??
for stomp boxes |
#2 |
Wow... what a question. What do you mean by that?
Considering low noise: BC550, BC556, BC549B, BC109B, BC547B, BC179, BC477, BC177. To make a final choice you will need to consult the tables of technical data which are normally provided in catalogues. I suggest this site: http://www.im.pwr.wroc.pl/~med/jn/karty_katalogowe.html .pdf files provides information you need. Peace! TH.J.B
Success is the ability to go from one failure to another with no loss of enthusiasm. |
#3 | |
Only none of these are germanium. |
#4 |
that's definately true
#5 |
These seem to be the most popular:
PNP NKT275 - the best OC44 OC75 AC128 NPN AC176 AC127 OC140 Regards Tony |
#6 |
Ups... I forgot... what a shame
Peace! TH.J.B
#7 |
anyone remember the OC71 ?...oops, showing my age...
(used to be common in the 60s, and you could scrape the paint off and make a phototransisitor...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#8 |
OC71 - Ive got about a dozen of these nicely scraped awaiting an application
Tony |
#9 |
if you are looking for
germanium power transistors ( >= 1 Ampere ) it is not many complementary pairs PNP + NPN There are however some powerful devices. I have found one guy selling NEW EXEMPLARS in Original Package of these: > 2N268 .. PNP .. 80Volt 3Ampere 30Watt .. looks almost like TO-3 > OC16 .. probably PNP ...in older power case They do NOT come cheap ![]() Complementary Pairs. Often used are: -------------------------------------- AC127 + AC128 0.3 / 1 Watt AC187 + AC188 1 / 1 Watt So AC187 (npn) + AC188 (pnp) are one of the few Pairs above 1 Watt See attached picture of 2N268, 30 Watt PNP
lineup |
#10 |
There are lists with DATA specifications
of some Germanium transistors. I will put together one PDF or ZIP file, later. OC16 .. I mentioned is: PNP, 32V 1.5A 6.25Watt By the way, in Solid State forum if you post germanium question there you will probably get a lot more info from Older Electronics Repair Service members. We have quite a few of those at www.diyaudio.com I know Enjoy ![]() Lineup Germanium Transistor History & Info forum
lineup |
| AC128 PNP Germanium Transistor Spice Mode (RARE!) | pweaudiotech | Solid State | 57 | 11th January 2011 11:55 AM |
| germanium Preamp? | prorms | Solid State | 116 | 22nd December 2009 04:33 PM |
| Need Old Germanium transistor datasheets | Bakmeel | Parts | 9 | 3rd June 2009 07:43 PM |
| What to do with my germanium transistors | keantoken | Parts | 7 | 6th April 2008 05:05 AM |
| Germanium transisors and gm | Steve Eddy | Solid State | 3 | 13th January 2007 03:38 PM |
| Page generated in 0.09838 seconds (80.39% PHP - 19.61% MySQL) with 11 queries |
