Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd July 2008, 02:52 AM   #1
Question Fender twin reverb farts out after switching to standby
Hello, I have a Fender silverface twin reverb circa' 1969, it started to make an strange kind of a fart out noise shortly after switching to standby mode having the amp on.
I visually inspected the power tubes and discovered that one of them had a blue haze, which I think it was not the problem, however a couple of days later and soon after I turned the amp on a loud buzzing noise was heard which became gradually louder and I noticed that both power tubes had the same blue haze but this time as the buzzing sound increased its volume the power tubes' glow became more blueish and almost the entire tubes were glowing blue, then I switched the amp off and checked the power tranny which I believe was hotter than normal.
Then I changed the offending pair of power tubes with a fresh set but the same thing happened, I noticed that if I turned the amp on on standby mode the blue glow wasn't there and until I defeated the standby switch the blue glow appeared on a pair of power tubes.
I checked the B+ and seem to be normal around 430V, checked the bias voltage and it was around 50V. About 6 months ago I recapped the power supply and it was working fine until now. The vibrato effect doesn't work as well, but my main concern right now is the power tube section problem, any advice will be appreciated, thanks in advance.
Old 19th July 2008, 05:42 AM   #2
Send a message via Yahoo to Deep Surplus
I'm not an expert amp repair technician, but no one else has answered... (and I work with one), have you tried swapping you're preamp tubes yet? One of them should be driving your vibrato section... if there's something wrong in the preamp section of your amp it could be affecting the problem in the output tubes, hope this helps...
Dave
Old 19th July 2008, 06:52 AM   #3
Send a message via AIM to DigitalJunkie
Is that +50V,or -50V? (it should be -negative!)
It sounds like it might have lost bias,hard to say.
Looks like there are some schematics at the bottom of this page:
http://www.ampwares.com/ffg/twin_reverb_sf.html
Fender twin Reverb theriffa Instruments and Amps 1 11th May 2008 02:15 PM
Fender super twin reverb jazz Instruments and Amps 1 4th September 2007 08:30 PM
Can you run a Fender Twin Reverb with only two 6L6's? garrett_92exp Tubes / Valves 5 3rd February 2006 11:34 AM
Building a fender twin reverb in the UK bigparsnip Tubes / Valves 11 5th June 2004 10:56 PM
Good old Fender Twin Reverb Netlist Tubes / Valves 9 14th January 2004 01:55 AM
Page generated in 0.08056 seconds (72.60% PHP - 27.40% MySQL) with 10 queries
