Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th May 2008, 10:37 PM   #1
Default question regarding guitar amp line out
hi, i just purchased a crate gx-65 from a previous owner, but i'm not quite sure if it has a line out jack. i'm new to guitar, so naturally im new to amps too. i noticed it has a insert jack switch and an external speaker jack switch, and a footpedal switch. are any of those applicable? i just want to use the lineout so that i can record my guitar onto the computer, as i don't know any other way to record
thanks so much
Old 28th May 2008, 10:28 AM   #2
http://www.crateamps.com/pdf/manuals/GX65.pdf
The Insert jack (#15) lets you patch external effects
into the amplifier just prior to its power amp stage.
Correct me if I'm wrong but this is a bit naff having insert post reverb.
However it is ideal for what you want - a line out post reverb.
/sreten.
What do I need to run a signal from guitar into a Windows PC Line In zobsky Instruments and Amps 13 11th March 2009 11:49 PM
guitar amp question nhuwar Instruments and Amps 2 10th February 2009 05:28 PM
EDCOR Releases Line of Guitar OPT's Geek Tubes / Valves 33 6th February 2009 01:13 PM
2x12 guitar cab for Line 6 Spider III HD 75 Andronico Instruments and Amps 9 28th December 2007 10:08 AM
Multi-purpose tube amp (line and guitar inputs) smsmonster Tubes / Valves 28 20th May 2006 12:12 AM
Page generated in 0.05310 seconds (79.48% PHP - 20.52% MySQL) with 10 queries
