| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#71 | |
With regard to the gain of the unit, I am only usig active basses and when I originally built mine I noticed it had waaayyy to much gain. So when I rehoused it (see earlier in this thread) I added an L-pad input attenuator (two resistors and a switch), and I also tacked a 200k resistor over the 100k plate resistor of the second stage, that tamed the gain excellently! And the tubes make a big difference as well, I tried a couple of different ones, thinking that it shouldn't make that much of a difference, but it really does. I am very happy with the ECC803S which is in there now.
Oemptempa petoempetapap |
#72 | |
Another change, which is not related to your problem, is adding a gridstopper for the second tube. Sometimes I notice a very loud hum when I have used the unit for a bit and then close the volume control all the way. I think (but I'm not sure) a grid resistor would remedy this.
#73 |
Why would my tonestack caps need to be rated for 300vdc? When I measure the voltage after the 100k resistor its well under the 200vdc they are rated for... I'm confused...
#74 |
Aahhh, after some reading I see now the importance of their being a higher value. Thanks for the suggestion, I'm off to get some 300+ volt rated caps!
#75 |
#76 |
In some of the schematics, there is no cap (other than the tonecaps) between the plate of the first stage and the pots for the tonecontrol. If the tonecontrols are not rated for the full voltage, than there will be DC on the pots. An alternative solution to this would be to add a 100nF cap right after the plate of the first stage put before the tonestack.
#77 |
I've done all the power supply caps and resistor upgrading, The amp subjectively sounds quieter and much more punchy to me now.
I'm going to put the 100nF cap in soon, I'll report back, it's a really interesting idea. I think I'll also be doing a small choke in the power supply in place of the first 1.5K resistor. It's plenty quiet already, but now my obsessive nature has taken over! LOL |
#78 |
LOL, yeah, sometimes you just have to give in to that OCD. Mine's got 3x 450uF on the B+, perhaps also a bit excessive for a single tube :-)
Rectified and regulated heaters are a must, IMHO.
#79 |
Are you using that cap as a 'choke'? I'm guessing that would roll off some lows, or something wouldn't it? I don't want to change the tone, just use a choke to perhaps quiet any ripple that still gets through.
Thoughts? |
#80 |
Well, it does help to get rid of ripple, but it's not a choke, it's a CRCRC filter. And it's on the B+ high voltage supply, so no signal passes through it. I also needed to drop quite a bit of voltage, because of the transformer I had, so the series resistors between the caps are something like 10k and 15k.
| Alembic F2-B project gone cookoo | Nordskov | Instruments and Amps | 3 | 17th June 2009 09:03 PM |
| Alembic SF-2 Super filter Schematic ? | FUCHSAUDIO | Instruments and Amps | 7 | 29th July 2007 08:32 PM |
| Pre/PS ala Alembic | croat47 | Instruments and Amps | 3 | 16th March 2006 02:50 PM |
| Alembic F-2B | mbonus | Tubes / Valves | 3 | 3rd March 2006 05:55 PM |
| Page generated in 0.11159 seconds (80.92% PHP - 19.08% MySQL) with 11 queries |
