| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 |
The pickup height adjustment is dependent upon the design of the pickup you're using.
Of significant importance is the design of the magnetic field, which is focused to a specific region above the pickup. But contrary to manufacturer recommendations, most players with practical experience using Fender's new "Noiseless Pickups" product line know that they tend to work better when set lower than the recommended height (spaced futher from the strings). At the suggested height, most players complain that they sound way too thin - weak sounding. Lowering the pickup height tends to fatten it up. Maybe the original spec sheets contained a misprint? In any case, it's worth experimenting to find out what pickup height works best for your hardware and tastes. Just for reference, here is a screenshot of Fender's recommendations for setting up a Stratocaster. Fender offers a fairly good selection of setup guides in their support library. They provide a lot of GENERAL information that is not specifically limited to Fender guitars, as much of the theory is universal to all guitar types. Might help to research "Intonation," and "Equal Temperament Tuning" on Google before you do anything. Good luck!
Writing is good exercize for the texticles! |
#12 |
also remember that if you change string types (different thicknesses and formulations) you will want to adjust the pickups again, and may have to redo the intonation, since a change in string type brings changes in the string tension, which changes the bow of the neck slightly. that's why a lot of guitarists stick with a certain brand and type of string once they find what they like best. you also want to avoid hanging the guitar on a headstock hook for long periods of time or using a stand that holds the guitar by the headstock, since it can cause the neck to twist. i've seen it happen. if the guitar is going to be stored any length of time, or if its going to be exposed to extreme cold (such as in the cargo hold of an airplane) loosen the strings until they barely start to flop. extreme cold shortens metal, which increases string tension AND truss rod tension and can break the neck
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
| (1/12th etc..) Octave Smoothing Algorithm | digidocs | Multi-Way | 1 | 14th February 2007 07:37 AM |
| 12th annual AES Conv./Show in San Francisco | FastEddy | Instruments and Amps | 6 | 7th October 2006 08:42 PM |
| Singapore DIY Event - 12th March 2005 | EchiDna | Everything Else | 3 | 10th March 2005 07:48 AM |
| What is an harmonic? | Bricolo | Solid State | 24 | 26th December 2002 05:34 AM |
| Page generated in 0.08240 seconds (68.33% PHP - 31.67% MySQL) with 10 queries |
