Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st February 2008, 04:38 PM   #1
prorms is offline prorms  United States
Send a message via ICQ to prorms
Default does someone have a good cmos overdrive schematic ???
does someone have a good cmos overdrive schematic??
Old 22nd February 2008, 08:15 PM   #2
unclejed613's Avatar
any particular reason for it being cmos?
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 22nd February 2008, 09:04 PM   #3
I have heard this is suppose to be good, doesnt take long to bread board it and try
http://www.freeinfosociety.com/elect...iew.php?id=325
www.tonepad.com have some stuff as well
Dave
Old 24th February 2008, 02:04 AM   #4
the hex inverter fuzz...... actually i find a TL072 more flexible and stable. also, the problem i see using a CMOS chip for a fuzz is a reliability issue. static electricity, just from plugging the cable into a guitar (all it takes is a measly 250V charge) to turn the hex inverter into a "never" gate, or a "pop amp".... bipolar and jfet inputs are a lot more forgiving of static discharge.if you can feel a static discharge on your fingertip, you're already up to about 5kV, so a charge that would damage the input of the CMOS chip might never be noticed, and suddenly the fuzz box no longer works.
Old 26th February 2008, 04:59 PM   #5
I agree with unclejed613, however there are several ways around this static problem such as using clamping diodes, or even better using a simple capacitor coupled pre-amp before the cmos stage (transistor, op amp etc...) there are ways around it, best is try breadboard the circuit and try it out for your self. good luck.
Dave
Old 26th February 2008, 08:43 PM   #6
no particular reason just wana try it out
Old 2nd March 2008, 05:27 AM   #7
the following is what i use often as an onboard preamp. i usually use a TL062, not the LT part. if you want variable gain, use a pot for R3. the first half of the op amp is used as a "rail splitter" to provide a +/-4.5V supply from a standard 9V battery. the same principal can be used with a quad op amp, leaving 3 active sections available for preamp, tone control, etc...
Old 3rd March 2008, 10:33 AM   #8
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Have you checked out the designs available at http://www.runoffgroove.com/articles.html ???
what is the best overdrive schematic???? prorms Instruments and Amps 6 2nd August 2008 02:34 PM
need schematic for 12au7a distortion overdrive and fuzz prorms Instruments and Amps 4 4th February 2008 05:53 PM
12AU7A: I need fuzz, overdrive and distortion schematic prorms Tubes / Valves 1 12th January 2008 04:14 AM
3.3v to 5v CMOS interfacing Zodiac Digital Source 9 15th May 2006 10:11 PM
Recommendation for a good CMOS op-amp? rruss Solid State 8 20th October 2004 08:39 PM
Page generated in 0.11402 seconds (71.16% PHP - 28.84% MySQL) with 11 queries
