| Instruments and Amps Everything that makes music, Especially including instrument amps. |
is thier away get ride of the hum and hiss in this fuzz schematic?????
it just a simple fuzz stomp box schematic when you turn up 3/4 way gets realy bad |
#2 |
I can't speak to the hiss... but the hum is coming from your guitar or the environment.
The circuit MAY be happier in a metal box. As far the the guitar is concerned... that's why they make humbuckers... |
#3 |
Emitter-to-ground for a 2N5088 is baaaaad. Their beta is way too high (I've measured them up to 600!). You need an emitter resistor (bypassed) to control it. That'll drop your hiss by a good 20dB+. Also, you want your output cap on the other side of that 1K resistor and reverse the polarity of both the input and output cap. Cheers! |
#4 |
You might know this site: Generalguitargadgets
There are some good infos and schematics. With a fuzz you'll always have a lot of noise and hiss. You could use a noise gate to have silence while not playing. |
#5 |
Without and emitter resistor on the first stage, you're probably loading your guitar pick-up down pretty hard too. With an resistor of 750 - 1.5k on the emitter, you'll have a lot higher input impedance. -tINY |
| Fuzz Face DIY: need more fuzz | ThomasDIY | Instruments and Amps | 12 | 17th September 2009 03:06 AM |
| is thier away to turn alphadrum schematic into a guitar effect | prorms | Digital Source | 0 | 22nd February 2008 03:38 PM |
| need schematic for 12au7a distortion overdrive and fuzz | prorms | Instruments and Amps | 4 | 4th February 2008 05:53 PM |
| 12AU7A: I need fuzz, overdrive and distortion schematic | prorms | Tubes / Valves | 1 | 12th January 2008 04:14 AM |
| Page generated in 0.08455 seconds (64.94% PHP - 35.06% MySQL) with 11 queries |
