Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 23rd November 2007, 12:50 PM   #1
jackinnj's Avatar
Default Recommend a 2W, Class D mono for guitar
Last evening, as we were parting from the relatives after Thanksgiving dinner, my nephew asked if I could repair his son's guitar amplifier -- the youngster has a Gibson which looks like Tiny Tim's ukelele -- the amplifier has a jack for a 9V wall wart so will probably have to put in a buck converter as most of the Class D amps are 2.5 to 5.4V with built in voltage boosters.
I would prefer not to have to use BGA or micro-SMD but SOIC is fine.
how many mV does an electric guitar pickup put out anyway?
Old 23rd November 2007, 08:25 PM   #2
Geek's Avatar
Default Re: Recommend a 2W, Class D mono for guitar
Can't help with the rest, but...
Based as a 20mV standard. Cheapies put out less, hot boutique pickups significantly more.
Cheers!
Old 24th November 2007, 03:58 AM   #3
unclejed613's Avatar
hot pickups can go as high as 1.5vrms. average cheapo pickups usually in the 20-100mv range.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 24th November 2007, 05:15 AM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Jack, you've got a lot to choose from. There are parts from TI, National, AD, Maxim, Monolithic Power, etc. Just about any of them should be fine for a guitar amp.
Brian
Old 27th November 2007, 05:27 PM   #5
Minion is offline Minion  Canada
I know it isn"t Class D ,But if you only need 2w and want battery power you might consider useing the LM386 IC.... I believe they can put out 1 or 2 w and can be Paralelled and Bridged for more output power and they are easy to use and sound pretty good in guitar amps....and you can probably find some in 8 pin DIP...
http://cache.national.com/ds/LM/LM386.pdf
Old 28th November 2007, 02:36 PM   #6
-->jackinnj, do as Minion say (LM386 works in class B, it is not class D but will do the work ).
There is neat little guitar amp called "Little Gem mkII" - 9VDC power supply, two LM386 (in BTL).
Use LM386N-3 or LM386N-4, then You can squeeze 2W from it
http://www.runoffgroove.com/lgmk2-pcb.pdf
http://www.runoffgroove.com/littlegemMK2.png
Old 1st December 2007, 05:10 PM   #7
Nordic is offline Nordic  South Africa
Nordic's Avatar
Just finished a gem II... it is asoundingly loud, for such a low supply voltage
Old 2nd December 2007, 11:14 AM   #8
Andronico's Avatar
You can try the ¨Little Rebel¨ too, it sounds very good and the name is cool.
http://rebel.massberg.org/index.php
Old 2nd December 2007, 01:53 PM   #9
getafix is offline getafix  Philippines
getafix's Avatar
or how about a noisy cricket by beavis audio
http://www.beavisaudio.com/Projects/NoisyCricket/DIY/
forever dreaming of a better set-up...
Old 2nd December 2007, 08:37 PM   #10
jackinnj's Avatar
Nope, I am surrendering and gonna' use BGA -- TPA2010 -- they cost $1.55 -- filterless mono 2.5 watt and can run it off of a pair of "C" Cells.
recommend discrete Class D rellik Class D 11 3rd November 2005 01:27 AM
recommend a 5Y3 based bass guitar amp? elementx Tubes / Valves 0 29th October 2005 08:14 PM
Pls recommend a good class-A goldyrathore Solid State 24 15th July 2005 03:50 AM
Page generated in 0.10432 seconds (75.38% PHP - 24.62% MySQL) with 11 queries
