| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#31 |
Thanks Trout.
Looks like i'll try a Fender Pro then. Some simple questions (wouldn't be any fun with out them Can i drop one of the 12ay7 stages? I only need a single input. Can i add a "master" volume control after the preamp stages so i can have the distortion, but without killing my ears? I play in a small room most of the time. If i understand this right, i would replace the 56k resistor before the 6l6's with a 1M pot, with coupling caps on the legs so no dc gets to the pot, correct? I'm looking at this 5e3 schematic. http://www.ampwares.com/ffg/schem/pro_5e5_schem.gif I would connect the pot exactly like it is connected in the Spitfire schematic, correct? http://www.diyguitarist.com/Schemati...eSchematic.bmp Thanks for the help.
AJ |
#32 | |
In Fact, it had little or no effect on the overal tone quality to my ears. Take a look at the Master Volume in this drawing. Simple parts needed, (2) ,022/600V caps, (1) 1meg pot. I found that you can get some great overdriven tones cranking the pre-amp volume and not get the ear bleeds. It is a different type of distortion though. More of a traditional pedal sound and no output tube growl of a fully cranked amp at low volumes. I would not use that paulC mod on that page though, it sounds nice, but it appears to be pretty hard on the output tubes. trout |
| Fender Champion 110, upc1188 | drummer_Dave | Instruments and Amps | 18 | 16th March 2009 02:17 AM |
| Fender Champion 110 | jam9 | Instruments and Amps | 5 | 31st January 2009 03:41 AM |
| Praxis vs Sample Champion | Erik F | Multi-Way | 4 | 11th November 2008 08:42 PM |
| Sample Champion and measurement mics? | BenLilly | Multi-Way | 1 | 11th March 2003 05:24 PM |
| Montreal Alouettes is the 2002 Grey Cup Champion | FrankDIY | Everything Else | 0 | 25th November 2002 02:13 AM |
| Page generated in 0.09162 seconds (70.19% PHP - 29.81% MySQL) with 11 queries |
