| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hi everyone,
I want to use headphones with my guitar amp (head not combo), but there's no headphone socket. From research I've done so far, I understand I probably can't plug the headphones directly into the speaker output. Can anyone please advise on what I need to do? |
#2 |
Resistive divider to drop the level down.
#3 |
First question - what type of amplifier is it?
If it is has a valve output stage, then you will need to dummy load the output, which is fairly inconvenient. If it is a transistor amp, then no problem - a suitable resistive divider might consist of a 100 ohm resistor in series, wired from the output to the commoned tip and ring of the headphone jack socket, with a 10 ohm resistor in parallel (from common tip and ring to the sleeve). The sleeve connects back to the amp. 2 watt rated resistors ought to be fine - unless you want to play REALLY loudly....!
John Audio |
#4 |
Thanks both for your replies.
The amp in question is an Ashdown MAG300H. Its technical spec is here: http://www.ashdownmusic.com/bass/detail.asp?ID=112. I believe it is all-transistor. The minimum output loading is 4 ohms. John, I'm afraid I'm being somewhat dim but I'm finding it hard to form a clear mental picture of the scheme you're suggesting & I don't want to run the risk of messing-up. Would it be possible to post a simple sketch, please? Cheers, Mike |
#5 |
Can't send you a PM - so you will have to e-mail me via my Web site:
www.orchid-electronics.co.uk JG
John Audio |
#6 | |
From John's suggestions, R1=100, R2=10, Rsource=0, Rload=headphones, Vin is amp output, +=positive, -=negative |
#7 |
Thanks, I'll give it a try.
| AMPLIFIER ( MIC imput, HEADPHONES output)?? | medogrizli | Chip Amps | 2 | 30th May 2007 04:30 AM |
| AMPLIFIER ( MIC imput, HEADPHONES output)?? | medogrizli | Solid State | 1 | 28th May 2007 12:31 PM |
| Headphones output to line level | Simpleton | Parts | 1 | 13th May 2007 09:54 PM |
| Series connecting output Transformers. | Shoog | Tubes / Valves | 55 | 12th February 2007 05:22 PM |
| Ok to run high-end headphones with amp output? | The Paulinator | Solid State | 15 | 17th April 2004 07:08 PM |
| Page generated in 0.08934 seconds (77.90% PHP - 22.10% MySQL) with 10 queries |
