Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th October 2007, 02:32 AM   #1
Default albert kreuzer bass pre amp
can anyone help me simplify the wiring details realistic draw if posible
Old 13th October 2007, 03:38 AM   #2
Default bass pre amp
here is the schematic
Old 13th October 2007, 01:51 PM   #3
What are you wanting to try and simplify?, it's a simple enough little circuit, and he even gives you a nice easy PCB layout.
Nigel Goodwin
Old 14th October 2007, 07:58 AM   #4
Default pre amp
i already made the board and completed all parts exept the wiring,any one who can give me idea of the actual wiring of pots and switches much welcome
.thanks
Old 14th October 2007, 08:07 PM   #5
Minion is offline Minion  Canada
Through some very simple deductive reasoning (I mean very simple) you should be able to easilly figure this out by simply looking at the schematic and at the PCB.....
Hint: The pots and switches are labeled on both the schematic and on the PCB....They are labeled P1,P2,P3 ect (For pots) and switches are S1,S2,S3 Ect, power supply should be easy to figure out.....
here"s another hint: CW and CCW means Clockwise and counter Clockwise .......
Old 3rd January 2008, 11:44 PM   #6
Default How did you do it?
So do any of you people who actually finished this preamp know how to select the source resistors for the JFET's? Please see this tread:
Help finishing Albert Kreuzer's preamp!
Thanks!
Eugenio
Help finishing Albert Kreuzer's preamp! Eugenio70 Instruments and Amps 13 27th September 2011 06:22 AM
Extra outputs for A. Kreuzer's Preamp? Eugenio70 Instruments and Amps 1 10th January 2008 08:12 AM
Ping Albert from Canada Shoog Tubes / Valves 0 18th May 2007 08:03 AM
Albert Kreuzer preamp scottyd Instruments and Amps 3 24th January 2007 01:46 AM
Jazz artists like Albert Collins Vivek Music 9 15th April 2004 05:03 AM
Page generated in 0.08983 seconds (71.79% PHP - 28.21% MySQL) with 11 queries
