twin reverb 100 watt - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd October 2007, 05:48 PM   #1
Default twin reverb 100 watt
I have an old 1973 Fender 100 Watt Twin reverb, it sounds clear and good, exept the Vibrato doesn't work. The speed control and intensity controls don't effect or change anything as far as the effects to the Vibrato go. I took the unit apart and inspected the wiring and circuits for obvious signs of damage, but all seems O.K.
All the tubes seem to be lit up O.K. I swapped the like tubes (12AT7's & 7025's) to see if that was a problem, but it didn't help. The foot switch doesn't turn the Vibrado on or off. The A - B ground switch didn't do any tricks either.It does turn off and on the Reverb. The foot switch is new. Tried with no foot switch plugged in also, no help.
Any ideals of what might be wrong with my unit?
Thanks.
Tim
Old 3rd October 2007, 10:07 PM   #2
Trout is offline Trout  United States
Trout's Avatar
I seem to recall a few threads on the same problem at a couple guitar amp sites I frequent. If memory serves, it was a capacitor issue in most cases. I forget the specifics.
I'll try to locate the info later this evening.
Trout
Old 4th October 2007, 02:29 AM   #3
m6tt is offline m6tt  United States
it's the oscillator...I am sure you can find the schematic online, but I believe trout is right on. I would imagine recapping an re-resitoring the oscillator portion of the tube would bring it back right away. You could also make sure that the cable hasn't broken on your footswitch. I have also heard that sometimes the Light Dependent Resistor unit goes out of spec, unfortunately I have not heard the greatest things about replacements.
Old 4th October 2007, 07:01 AM   #4
Geek's Avatar
Hi, maybe this will help?
I found the schematics here: http://www.el34world.com/charts/Diagrams.htm
Cheers!
Fender twin Reverb theriffa Instruments and Amps 1 11th May 2008 02:15 PM
Fender super twin reverb jazz Instruments and Amps 1 4th September 2007 08:30 PM
Can you run a Fender Twin Reverb with only two 6L6's? garrett_92exp Instruments and Amps 5 3rd February 2006 11:34 AM
Building a fender twin reverb in the UK bigparsnip Instruments and Amps 11 5th June 2004 10:56 PM
Good old Fender Twin Reverb Netlist Instruments and Amps 9 14th January 2004 01:55 AM
Copyright 1999-2017 diyAudio
