| Instruments and Amps Everything that makes music, Especially including instrument amps. |
who has the best cabinet design software for a 4 speaker
if help man of war speaker by Eminence |
#2 |
Typically guitar cabinets are not designed to any "Hi-Fi" standard. So software might be totally unnecessary. Bass cabinets are a bit more complicated and require some optimization. My suggestion to you would be to find a 4 driver cabinet that you like and copy the design. As far as software I like Unibox which is free. Since you are using Eminence drivers you could even try there own software.
Best of Luck.
If you take something apart and put it back together again enough times, eventually you will have two of them. |
#3 |
Can I modestly recommend my thread here:
http://www.cohrs.ca/var/www/html/sta...pic.php?t=1029 I just finished building a bass cab with an Eminence Legend CB15. That's the build log. It's a 1x15 instead of a 4x10, but I think you'll learn a lot.
-Paiku |
#4 |
so you use WinISD software ????????
is the bass real bright when on the treble almost as a guitar |
#5 |
Yep, WinISD Pro (for some reason, both the base and Pro versions are free -- get the Pro). It's a great tool.
The treble is not bright at all, not with a 15"!! The bass is nice and tight. Lots of deep bass without being boomy. But there aren't a lot of highs. I plan to build a 2x10 or something similar, to go on top of the 1x15. Eventually.If you build a 4x10 or 4x12, you could get a lot more highs and a really sweet tone, but you may have trouble getting response down to 41Hz. It's a trade-off. Deep, tight, small - pick any two. Here are a couple of articles that I found really helpful: http://www.geocities.com/SunsetStrip...1/speaker.html http://www.activebass.com/default.as...m.asp%3Fi%3D63 Good luck,
-Paiku |
#6 |
I really want to build a bass cabinet like your's to complete my SWR 12. But I cannot acced to your thread for more détails. Thank you to help me.
Pierre |
#7 |
Hi Pierre,
Trinity Amps has updated their forum URLs. Here is the current link: http://www.trinityamps.com/phpbb/viewtopic.php?t=1029 Hope it helps,
-Paiku |
#8 | |
"1. Buy an instrument speaker driver for an instrument cabinet. Avoid the temptation to use a hi-fi or PA driver, no matter how awesome its specs seem to be. The results would be a cold-sounding cab that would be vulnerable to damage." Avoid hifi drivers, yes. Pro drivers however are generally rated at higher thermal power than instrument drivers and often longer excursion. Two of the best current drivers for bass are the Eminence 3015 and 3015LF. A well implemented pro driver is less likely to sustain damage in normal use if properly integrated with the cab. I use pro drivers exclusively for the lower registers. Tone is personal, so I have no issue with the 'cold' comment, except that I don't agree myself. There are also a large number of bassists who don't agree with the idea that single driver, or multiples of the same driver are the way to go. I play a wide variety of music and I don't want the cab to impart it's own indelible signature on everything eg many Ampegs esp 8x10's. My cabs are moving towards quality multiway PA style rigs with tonal changes coming from the amp and FX, and of course my hands. I also use 5's as well as 4's. |
#9 |
Hi Brett, thanks for expanding on that point, I'm sure you're right. The "advice" that I posted in my thread on Trinity Amps' forum was little more than a summary of what I'd learned through research, before I started building my cab. I did find a lot of hobbyists who were building with pro PA drivers. For regular electric guitar, the tonal difference is probably greater than for bass.
Also, there are two schools of thought on how to produce the desired tone. One is to make your amp and speakers as clean and transparent as possible, and then find or develop the right effect or combination of effects to get the desired sound. The other (favoured by the vintage gear nuts I hang out with) is to choose the guitar and amp themselves to produce the tone you want. I admit that the latter path leads to a basement full of guitars and amps! One more comment; my finished cab is HUGE. It's about 80lbs and the size of a large CRT television. I haven't moved it out of my basement since completing it. If I'd been open to using a pro PA driver, I might have been able to get the same low-bass extension with a smaller cabinet. Oh well, live and learn! Thanks again,
-Paiku |
#10 | ||
I was tired when I posted earlier and called your article interesting. I feel it's an excellent how-to primer and a noob could gain a lot from it. Quote:
Cheers |
| I need 3D CAD Cabinet ONLY Modeling Software | sdep777 | Multi-Way | 5 | 18th November 2008 09:08 PM |
| speaker cabinet software who has the best | prorms | Multi-Way | 4 | 27th September 2007 03:56 AM |
| Cabinet Design Software | DRoy | Multi-Way | 4 | 25th July 2005 06:47 PM |
| Does anyone here use Ouickroute EDS 3 design pcb design software? | setmenu | Everything Else | 2 | 18th March 2004 01:23 PM |
| Page generated in 0.12998 seconds (79.04% PHP - 20.96% MySQL) with 10 queries |
