| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Anyone have a schematic ?
#2 |
This is gonna be tough to obtain. All of the Alembic electronic devices are of a "secret" and proprietary design, just so folks don't copy them and "knock them off" ...
" There is no other preamp, graphic EQ, parametric EQ, or filter unit anywhere from anyone that can shape tone like the Alembic SF-2. ..." >> http://alembic.stores.yahoo.net/sf2superfilter.html The factory is down the freeway from me about a half dozen miles, and when I visit, they are always cagey about their parts sources, schemos, tricks, tips and traps ...
Over compression is a problem with modern CD recordings |
#3 |
Ironic, considering their F-2 B is basically a Fender Bandmaster preamp in a rack cabinet.
Thanks for the reply. |
#4 |
" ... considering their F-2 B is basically a Fender Bandmaster preamp in a rack cabinet. ..."
Then there should be no real problem figuring out the schematic, right?
#5 |
Nah, the F-2B is their tube preamp, the Super Filter is a whole other product.
#6 |
" ... the Super Filter is a whole other product. ..."
Same, same .. a rose by anyother name still smells as sweet. Granted that the two devices are slightly different, the SF-2 being a pre-amp with additional tone manipulation circuits and controls, the basic input and output is that of a tube pre-amp. In either case, good luck finding a schematic for either.
#7 |
" ... the basic input and output is that of a tube pre-amp. ..."
Oops, I see what you mean, the SF-2 is pure solid state ... my boo boo. But the I/O is still similar to a tube pre-amp = input and output impedence are the same as the other Alembic stuff.
#8 |
An SF2 is basically a two channel state variable filter with selectable LP/BP/HP switching and a dry/wet mixer.
http://www.alembic.com/prod/sf2.html |
| Alembic F2-B | phil mailloux | Instruments and Amps | 101 | 12th October 2011 02:07 PM |
| Alembic F2-B project gone cookoo | Nordskov | Instruments and Amps | 3 | 17th June 2009 08:03 PM |
| Pre/PS ala Alembic | croat47 | Instruments and Amps | 3 | 16th March 2006 01:50 PM |
| Alembic F-2B | mbonus | Tubes / Valves | 3 | 3rd March 2006 04:55 PM |
| Super Capacitor for Power Supply Filter | davidallancole | Solid State | 7 | 18th December 2005 10:13 PM |
| Page generated in 0.09629 seconds (77.26% PHP - 22.74% MySQL) with 10 queries |
