Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th July 2007, 08:01 PM   #1
Dtorre is offline Dtorre  United States
Send a message via AIM to Dtorre
Default Please Help With Wireing My Cab!!!
im basicly building my cab from the empty shell of a marshall avt150h cab (which has one speaker cable input) and i have 4 12" celestion speakers that are 16 ohm each... the head i want to use is a marshall MODE 4 head which has only 8 and 16 ohm outputs. i know i cant wire these speakers to 8 ohms... so can someone either tell me in detail or give me a diagram on how to do this???? PLEASE... i just bought these amazing speakers, and am dieing to use them haha.
-Dave
Old 13th July 2007, 08:43 PM   #2
Petriej is offline Petriej  United States
Wire two of the drivers in series. (Group 1)
-Take a wire and connect the negative terminal from one driver to the positive terminal of the other driver.
Then wire the other two in series. (Group 2)
-Same as group 1 but the other two of four drivers.
Take the (unconnected) positive lead from Group 1 and connect it to the 16 ohm output. Take the (unconnected) negative lead from the other driver in Group 1 and connect it to the 16 ohm output.
Do the same thing for Group 2, so that your amp's 16 ohm output has 2 positive wires and 2 negative wires.
That should be a load as seen from the amp of 16 ohms.
Hope it sounds great! If you need a diagram I can prolly draw one up for you. Good luck.
Signature:
Optional signature you may use to appear at bottom of your signatures.
Old 13th July 2007, 09:25 PM   #3
yah, if you could draw a diagram that would be amazing.
Old 13th July 2007, 09:47 PM   #4
Hope this helps:
Signature:
Old 14th July 2007, 09:22 AM   #5
THANKS SOOO MUCH! it sounds absolutely amazing... and now i can rock with 320 tube watts of power haha!
Old 19th July 2007, 09:27 AM   #6
Hmmm .........
Its a valve / solid state hybrid, you likely need another 16 ohm 4x12
to liberate the full 350W. The effect of adding another 16 ohm 4x12
will not double volume (+10dB), it will add 6db, the stack will go as
loud as one 16 ohm 4x12 driven by 4 times the power.
Or in other words 3dB louder than a very similar 8 ohm 4x12.
/sreten.
Help with some speaker wireing please.... Minion Multi-Way 5 7th December 2008 01:01 AM
DIY attenuator (was silver wireing) Magura Parts 7 19th March 2004 02:05 AM
Shielded cable for internal amp wireing: where do I connect the shield? Bricolo Parts 11 26th June 2003 01:26 AM
Help with Tranny Wireing. jleaman Solid State 7 28th January 2003 04:51 AM
Atx computer powersupply Wireing schematic jleaman Digital Source 8 15th August 2002 09:59 PM
Page generated in 0.08850 seconds (72.48% PHP - 27.52% MySQL) with 11 queries
