| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 |
I guess you already figured it out, but in a blend pot, the internal carbon trace only goes halfway around. In the center, its the same as being at either extreme on a regular pot. You can make that extreme either ground or "hot", depending on how you wire it.
You wired it "wrong". Artie |
#12 |
i use a similar wiring setup for a phase reversal pot. the difference is that the pots are linear taper with a center detent, and the "output" and "ground" connections go to the neck pickup, and the other 2 connections go to the bridge pickup. with the pot at one end, the pickups are in phase (really bassy), at the other end out of phase (really bright), and at the center detent, the bridge pickup is out of circuit. this, however, would not work with the type of pots you are describing.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
| Looking for jazz bass and pipe organ | toenail | Music | 8 | 16th January 2011 05:56 PM |
| Fender Jazz Bass Mexico made | jazzman06 | Instruments and Amps | 1 | 10th July 2009 09:55 PM |
| Need a DIY Stereo Blend Control | x-pogo | Solid State | 8 | 8th July 2008 09:03 AM |
| Any Jazz or Jazz'n'Vinyl related forums on the net? | Onvinyl | Music | 2 | 18th May 2005 10:52 PM |
| pre amp blend system piezo/electret mic | partyjups | Solid State | 0 | 17th July 2002 01:12 PM |
| Page generated in 0.07226 seconds (68.39% PHP - 31.61% MySQL) with 11 queries |
