| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Alright, I plan to make a 4x12 guitar cabinet. Before I start I want to lay out all my plans. What I need to know is how to wire the cabinet so i have: a mono (8 ohm) input, individual left and right inputs (at 4ohms each) and an output.
To get a better Idea of what I want, look at this MESA jackplate. [IMG]I want to have the same wiring as this cabinet does. Does anyone know how I should go about doing this properly?[/IMG]
Made you look! |
#2 |
heres the image
Made you look! |
#3 |
I am pretty sure this would be correct, any one want to back me up on this.
check out this link it should help also http://colomar.com/Shavano/spkr_wiring.html good luck |
#4 |
Made you look! |
#5 |
Wow, thanks, just what i was looknig for. I plan to use this
Made you look! |
#6 |
Hey CG; One caution. If I'm reading that diagram correctly, and if you use grounded jacks, and if use a metal mounting plate . . . you'll have a dead short from hot to ground.
Let me study it some more, but I wanted to warn you before you fire anything up. Literally. |
#7 |
#8 |
that green path is a problem. The diagram is not correct. What you need to do is assume that they are switching jacks. That is each jack has four connections, with no plug inserted + joins +, - joins -, with a plug inserted only the input + and - connect to the lead. So you do not wire it as a normal parallel/series 4x12 for the 8ohm jack, as shown. The daisy chaining output socket is fairly obvious. The two 4 ohm jacks are wired into each series leg, and with no plugs inserted they provide the series connection represented by the green cross connection. This path should be broken by either 4 ohm plug. Make sure you get all your phasing correct. The switched tip of one 4 ohm socket connects to the switched ring of the other. The other two switched connections remove the connection to the 8 ohm socket.
#9 |
Thanks for the help, are you sure it won't work? I'm not really understanding what you're trying to tell me. Do you think you could draw up a simple diagram for me to follow!
Made you look! |
#10 |
I'm starting to understand, but Im still confused
Made you look! |
| Mono to stereo input wiring question | Keskin | Class D | 8 | 1st March 2009 11:33 AM |
| Xlr Stereo To Xlr Mono | jaya000 | Solid State | 4 | 9th February 2009 02:24 AM |
| Stereo/Mono 4x12" Marshall cabinet wiring | tone1963 | Instruments and Amps | 5 | 5th January 2008 09:17 AM |
| RCA: Stereo to Mono? | silentblackhat | Car Audio | 13 | 20th October 2007 04:06 AM |
| Stereo/mono wiring kinundrum | Krnichin | Multi-Way | 12 | 25th May 2006 09:44 AM |
| Page generated in 0.12673 seconds (82.83% PHP - 17.17% MySQL) with 11 queries |
