Go Back   Home > Forums > > >
Holton Precision Audio High quality, high performance amplifier modules and accessories
Old 2nd September 2016, 07:24 AM   #1
The Saint is offline The Saint  Australia
Default FS:HPA-NXV201PS Amplifier Module - End of Line Special!
End of line September special!
Normal Price is $269.00 each - Sale price $165.00AUD each.
See holtonprecisionaudio.com to purchase.
The nxV201PS is an end of line mini mono block amplifier module. Based on the very popular nxV200, the nxv201PS is designed to meet the needs of people who want an easier solution to building their own high quality audio amplifier.
With most audio module installations, wiring the power supply components can often be a very time consuming task and it is very easy to make mistakes, resulting in either damaging the amplifier or other components. The nxV201PS takes all that pain away by providing a high quality low noise power supply built into the main amplifier PCB. It features dual ultra high speed soft recovery bridge rectifiers and 10,000uf 63v main filter capacitors for each supply rail. This provides a low ground noise high speed supply right where the amplifier needs it. As close as possible to the main output stage, eliminating long power cable runs.
100 Watts RMS continuous sine wave into 8 Ω
170 Watts RMS continuous sine wave into 4 Ω
The HPA-NXV201PS is 2 Ω Stable
Biased into Class A/B
Power Bandwidth 3.5hz to 300khz -3dB
Dampening Factor At 100hz 8Ω = 800
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
SNR -105dB
THD-N = 0.005% @ 10 watts 8 Ohms
PSU Power Transformer secondary winding 35vac (225VA)
Old 5th September 2016, 12:53 AM   #2
Bump
FS:HPA-NXV201PS Amplifier Module - End of Line Special!Hide this!Advertise here!
FS: HPA-nxV101 R2 Signature DIY audio amplifier modules (2pcs.) pair Teti Swap Meet 7 10th May 2013 12:05 PM
Holton Precision Audio dual mono amp kit using hpa-nxv201ps modules Electro3000 Swap Meet 0 14th September 2010 07:51 PM
FS: Golden Tube Audio SE-300B II Special Edition Valve Amplifier coh-b-pyky Swap Meet 1 24th April 2010 08:31 PM
Endangered Audio - Gristleizer Module & New Module Line! endangeredaudio Vendor's Bazaar 0 5th March 2010 03:03 PM
Amplifier Special HPA-nxV200 The Saint Holton Precision Audio 0 7th August 2009 04:50 AM
