Go Back   Home > Forums > > >
Holton Precision Audio High quality, high performance amplifier modules and accessories
Old 5th September 2013, 09:59 PM   #21
Bigun is offline Bigun  Canada
Bigun's Avatar
My Holton amp builds.
My gosh !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 28th September 2013, 09:02 AM   #22
tane0019 is offline tane0019  Singapore
tane0019's Avatar
Originally Posted by Leikis View Post
36 pc for each channel Niching 2200 UFO 63 volt.
Hi Leikis,
I planning to build a class AB amp. A quick question on your build configuration.
Why 36pcs of 2,200 uF cap & not 6pcs of 13,200 uF ?
Does the sound quality improve when using more of smaller cap instead of lesser bigger cap ?
Thanks in advance.
Old 17th January 2014, 09:58 PM   #23
Leikis is offline Leikis
Here is my lates build. Stereo amp with 500R2
2x 1000VA 2x55 volt.
30pcs 2200uF 100 volt Roe for eatch channel (66000uF)
2xsoft start boards.
Dual mono with 2 iec power innlets.
Chassis from Along on Ebay.
Old 17th January 2014, 10:05 PM   #24
Originally Posted by tane0019 View Post
Hi Leikis,
Thanks in advance.
The use of several smal caps gives the psu extremly low inductance and it wil filter the power well. So ti wil be an very fast power supply. Very usefull when drivin low impedance speakers as my old Infinity speakers.
I have RS1 for the main stereo, for the the surround i have RS4000,RS3000, Kappa senter, in the living room Kappa 7.
As you mabye noticed Holton has the Psu Two with the same type of supply with many smal caps.
Old 17th January 2014, 10:45 PM   #25
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
nice
Old 13th August 2014, 08:01 PM   #26
My latest dual mono amp with the 500R2 boards is getting the new 500L boards. Realy looking forward to test the new boards.
Old 13th August 2014, 08:10 PM   #27
Looking forward to your comments Leikis. I think it will show pros and cons. Better image but less dynamic. Just guessing though.
Old 26th August 2014, 09:29 PM   #28
eduardokbb is offline eduardokbb  Brazil
I'm really excited waiting for your impressions regarding the sonic differences between these amps!
Old 12th September 2014, 07:15 PM   #29
The 500L boards in place in the amp, i painted the face plate in black gloss at the same time :-)
The boards came with pre adjusted bias at 43 mA for eatch transisstor.
Deskribe sound in english is not my strong side, ore writing at all !!!!
But right from a cold amplifier at first start ut, i hear the sound i AWESOME.
More open, sharp and clear, this is a run and buy produckt people. It fits my Infinity RS1 very good, the only play down to ca 150Hz, my mono Holton with 800 boards takes care of the bass system with 6 x 12" dipol for eatch side.
Even the midrange sounds more tigh and precise.
The goose bump factor is back :-)
Dont sitt on the fence, order now :-)
Old 12th September 2014, 07:24 PM   #30
Thanks for your feedback, Leikis!
My Holton amp builds.Hide this!Advertise here!
SSLV1.1 builds & fairy tales Salas Power Supplies 4198 20th May 2018 01:52 PM
Call for MyRef-C Builds & Photos bcmbob Chipamp 0 1st October 2010 10:57 PM
400 watt Holton amp upgrade Mattyo5 Solid State 31 19th June 2003 04:05 PM
Holton N-Channel Amp markkanof Solid State 1 17th June 2002 08:49 AM
Zen Revisited Vs Anthony Holton A/B amp FullThrottleRic Pass Labs 20 27th May 2001 01:29 PM
