Go Back   Home > Forums > > >
Holton Precision Audio High quality, high performance amplifier modules and accessories
Old 15th March 2012, 03:13 PM   #1
sonnya is online now sonnya  Denmark
sonnya's Avatar
Default HPA-nxV101 Signature
The looks is ... i lost my breath.....
Old 15th March 2012, 10:21 PM   #2
The Saint is offline The Saint  Australia
The Saint's Avatar
Hi Sonnya
Thanks for the complement
I am very happy you like it.
110 Watts RMS continuous sine wave into 8 Ω
180 Watts RMS continuous sine wave into 4 Ω
Biased into Class A/B
Power Bandwidth 3.5hz to 600khz -3dB
Slew Rate = 80v / microsec approximately
Dampening Factor At 100hz 8Ω = 800
Dampening Factor At 1khz 8Ω = 650
Dampening Factor At 10khz 8Ω = 250
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
THD+N @ 1khz 0.0045%
THD+N @ 10khz 0.009%
SNR -105dB
Recommended Linear Voltage Supply +-50 volts DC
Cheers
Anthony
Aussie Amplifiers
Old 11th May 2012, 06:59 AM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
been watching too
Old 12th May 2012, 11:00 AM   #4
supernet is online now supernet  Europe
supernet's Avatar
Looks nice
It is possible to attach THD harmonic components graph?
Old 13th May 2012, 02:09 AM   #5
The Saint's Avatar
Originally Posted by supernet View Post
Looks nice
Hi Supernet
I don't have the capability to produce the kind of graphs that an audio precision analyzer can do, but I might be able to output a basic frequency spectrum graph from my tektronics digital CRO if that would help?
Cheers
Anthony
Old 13th May 2012, 10:07 AM   #6
supernet's Avatar
Originally Posted by The Saint View Post
...but I might be able to output a basic frequency spectrum graph from my tektronics digital CRO if that would help?
That would be OK
Old 25th July 2012, 12:35 AM   #7
Sadface is offline Sadface
Am I correct in thinking that the power supply is integrated onto the circuit board and thus all that would be required would be a suitable transformer?
Old 25th July 2012, 12:55 AM   #8
The Saint's Avatar
Hi Sadface
Yes the power supply is built in to the main PCB and all that is required
is a power transformer to power it and a suitable heat sink to mount it on.
The recommended power transformer is 300VA toroidal core with 2 x 35VAC secondary windings.
The recommended heat sink would be a Conrad MF25-50 or something of similar
surface area.
I hope this helps
Cheers
Anthony
Old 25th July 2012, 01:46 AM   #9
The Saint's Avatar
Am I correct in thinking that the power supply is build onto the board for these and thus they would only require a suitable transformer etc for setup?
Correct, see above post for more info.
Cheers
Anthony
Old 28th July 2012, 01:28 AM   #10
Are you able to supply the appropriate transformers and heatsinks?
If so what would be the cost?
Many Thanks
Duncan Vella
HPA-nxV101 SignatureHide this!Advertise here!
HPA-nxV300 & HPA-nxV300se what's the difference? pcsl999 Holton Precision Audio 14 3rd September 2013 10:24 PM
HPA-2 headphone amplifiers kawo Headphone Systems 38 28th December 2012 12:41 AM
MI-HPA banginon Music 0 10th February 2011 04:40 AM
HPA NxV 550 or more Jman554 Holton Precision Audio 2 10th November 2009 09:04 PM
HPA-nxV201 Released Soon! The Saint Holton Precision Audio 5 23rd September 2009 05:33 AM
