#71 |
#72 |
I just received some of this for a couple of projects. when they say "cut to size" they mean beautifully machined to size
#73 |
Hi everyone,
I just purchased some of these heat-sinks last month and the problem mentioned before on post 57 is still present. They are concave by 1/32nd of an inch or .8mm in the middle of the 10 inch with. It was not mentioned anywhere on their site, just tough some of you guy's might want to know. Eric |
#74 | |
#75 |
30thou (=0.03" = 30mil = 0.762mm) of curvature in a 10.08" plate is roughly equivalent to a 35' radius on that plate. (actually, radius = 423.345") If you take a 1" wide heat source, say a To264 device and calculate what effect that radius has on the out of flatness between the sink and the device you will find that over the 1" of contact width, the maximum gap to be filled with conductive paste is ~0.3thou. Firstly the bolting of the device to the heatsink will pull in all of that gap (due to radius) to near zero. Secondly, the aluminium plate can have much of this radius eliminated by clamping a bar across the backplate. The force required and the stress set up in the aluminium can be derived from M/I = E/R = sigma/half thickness. sigma is the stress in the outer most fibre of the aluminium beam formed by the ~10mm thick plate. The only effect of that radius is aesthetic and can easily be solved by gently bolting the backplate to a properly machined case that has been manufactured to meet the users required tolerances.
regards Andrew T. Last edited by AndrewT; 20th May 2011 at 03:14 PM. |
#76 |
Is the 10.125" extrusion still available (as it's not on the website)?
(Or is it now the "10.080"?) Last edited by Andersonix; 18th July 2011 at 11:01 PM. |
#77 | |
Eric Last edited by Arick; 18th July 2011 at 11:19 PM. Reason: erasing the end of a sentence in the quote |
| Thread Tools | Search this Thread |
| 10" wide heatsink | barrredboss | Heatsink USA | 0 | 24th June 2009 10:50 PM |
| a picture of the new 10 inch wide heatsink | barrredboss | Parts | 1 | 27th April 2009 03:10 AM |
| 10.125" heatsink | barrredboss | Parts | 0 | 25th April 2009 04:01 AM |
| 10.08 wide heatsink die has been purchased | barrredboss | Heatsink USA | 3 | 31st March 2009 10:51 PM |
| 10.88 wide heatsink | barrredboss | Swap Meet | 0 | 23rd April 2004 07:09 AM |
| Page generated in 0.11235 seconds (77.20% PHP - 22.80% MySQL) with 11 queries |
