| Headphone Systems Everything to do with Headphones |
#41 |
I'll take a look. Is there any chance that the negative feedback could be fed through TWO small capacitors in series? that way the caps could block DC, and the AC signal would be twice-inverted and not make positive feedback..?
#42 |
No, you'd only need one cap in series with the feedback resistor to block DC. Caps don't invert signals, but at very low frequencies series coupling caps do introduce phase shift. This is workable though.
Brian |
#43 |
If you say so. I don't remember tenth grade physics that well... Anyway what size capacitor are we talking here? I've got a few cheap .22uF caps I could use, but I don't want to solder the bulky pots in there again. is 47K in series with .22uF a good start for feedback? I'm still using 7AU7's.
p.s. the amp sounds pretty good, very solid imaging and very little hum. i'm happy
| 12AU7 vs 12BH7 vs 6CG7 | SHiFTY | Tubes / Valves | 42 | 17th November 2011 03:05 PM |
| 12AU7/EL84 Headphone Amp | sorenj07 | Headphone Systems | 8 | 5th February 2008 04:44 PM |
| 12AU7 -> 12BH7 Do I need to change Rp? | zxx123 | Tubes / Valves | 3 | 3rd March 2005 12:41 PM |
| 12BH7 is microphonic | Original Burnedfingers | Tubes / Valves | 7 | 1st May 2003 10:35 PM |
