| Headphone Systems Everything to do with Headphones |
#31 |
Way too early to flail about with other tubes. The next step is to get those DC operating points right. I doubt they are. See my post above (we might have cross-posted).
Brian |
#32 |
Yes, Brian is right. I meant to say, "Replace the AC coupling to the White cathode follower with DC coupling." This morning was a bit panicked.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#33 | |
I actually DID disconnect the 1M grid leak, and left the .47uF/100K RC. However I just clipped the 1M at one point and bent the lead away so I can use a spot of solder to reconnect. I'll DC couple the gainstage to the top triode in the WCF. My MM actually gives me the low-battery sign now and then, but it seems to be working other than that. |
#34 | |
Brian |
#35 |
#36 |
Not weird at all. You are now drawing a sensible current in your output stage. You are now in a position to try beefier output valves (provided you bias them correctly), and re-instate the global feedback.
#37 |
Unfortunately, these beefier output valves (I have a quad of 6CG7's in my EL34 Williamson, for example) will probably draw more than .3A of heater current. As the PSU schematic I posted earlier shows, it's a contest between heaters and B+ headroom. I'll pop those 6CG7's in but hopefully B+ won't sag too much..
In order to provide some extra voltage swing to feed some NFB, might I try dropping a 6DJ8/6N23P into the first stage? I'd do a quick bias recalculation, but the extra gain might help, right? also, what value resistor might I try for NFB? I took out the pots already because I might want less NFB than 25K would afford.. |
#38 |
Have a look at the headwize site - there's extensive discussion and development of this circuit over there.
#39 |
Good, you've now got sane DC operating points. If and when you try global NFB, please do something to block the DC from the output. I couldn't readily find the referred-to circuit on Headwize, but they must show some means of providing DC-blocked feedback.
Brian |
#40 | |
As for DC on the output, I'd expect headphones to be particularly sensitive to it and produce unnecessary distortion as a result. Zero that DC offset!
| 12AU7 vs 12BH7 vs 6CG7 | SHiFTY | Tubes / Valves | 42 | 17th November 2011 03:05 PM |
| 12AU7/EL84 Headphone Amp | sorenj07 | Headphone Systems | 8 | 5th February 2008 04:44 PM |
| 12AU7 -> 12BH7 Do I need to change Rp? | zxx123 | Tubes / Valves | 3 | 3rd March 2005 12:41 PM |
| 12BH7 is microphonic | Original Burnedfingers | Tubes / Valves | 7 | 1st May 2003 10:35 PM |
| Page generated in 0.10655 seconds (77.59% PHP - 22.41% MySQL) with 10 queries |
