Headphone amp - low Z load and ... "echo" - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 27th March 2007, 09:46 PM   #1
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
Unhappy Headphone amp - low Z load and ... "echo"
My amp made with 6c4pi-ev and 6c45pi-ev works well with Sennheiser headphones. When loaded with 32 ohm headphones one can hear an "echo" effect - vocals are distant. Any guess why? Phase distortion?
Old 28th March 2007, 04:18 AM   #2
Geek's Avatar
Your headphones are either:
- Fed out of phase
- An incorrect contact is making them be fed in series (are they pushed all the way in?)
Cheers!
Old 28th March 2007, 07:49 AM   #3
yagoolar's Avatar
They are fed in-phase for sure. A bad contact is not an explanation. Those effects do not exist if I connect 300ohm Senns. I had had similar "echo/chorus" effect with Senns before I changed a coupling cap value to 1uF. I will attach schematics to help trace the bug.
Old 29th March 2007, 10:23 PM   #4
kevinkr's Avatar
How do you know there is not a contact problem with the 32 ohm phones - have you measured for continuity to all three contacts on the plug??
You provide almost no information about the headphone amplifier and yet you expect a reasonable answer, and when you don't get one you dismiss what under other circumstances would be a very plausible explanation. (I've had phones with a broken ground lead that caused a problem quite similar to your possibly inaccurate description.)
OTOH If this is an OTL design 1uF is way too small a coupling cap for 32 ohm phones - I would recommend a minimum of 100uF and preferably 220uF or more, but I can't be sure without knowing more about the design. The -3dB point with a 1uF cap and 32 ohm load is almost 5kHz which might be why vocals sound so distant, and there would also be no bass. 220uF would give you a -3dB point of about 22Hz.. For acceptable performance with a 300 ohm headphone you would need at least 20uF!
Please post a schematic, or at least tell us whether this amplifier uses output transformers or is an otl of some sort.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th March 2007, 10:52 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It would be great to get echo/chiorus effect such a way, without complex digital /noisy analog time delays, etc...
The Devil is not so terrible as his math model is!
Old 30th March 2007, 09:42 AM   #6
yagoolar's Avatar
Yes, I have measured it. They are ok - I have tested it also with other headphones (sennheiser).
The Phillips HP1000 are also ok - tested with other amp.
I did not mean to be rude and in fact, after I had fired the amp the sound was strange - I had forgotten to connect gnd of the socket! That is why I said so. Sorry for my English.
Find the schematic attached. TIA
Old 30th March 2007, 10:08 AM   #7
The effect described above is exactly what happens when there is no ground connected on the phones. Then everything that is in the center (like solo voice for instance !!!!!) is missing and only the parts that are different between left and right is heard (like stereophonic reverb for instance).
Charles
Old 30th March 2007, 10:15 AM   #8
yagoolar's Avatar
May it imply different cable connection in HP 1000 than in Senns? Hm, must re-check it with right-left channel tests.
There is the picture.
diy Audio Photo Gallery
Old 30th March 2007, 01:06 PM   #9
dnsey is offline dnsey  United Kingdom
Have you taken the obvious step of testing your 32 Ohm phones (and their lead and plug) with a different amp, to eliminate the most likely fault area?
Old 30th March 2007, 01:09 PM   #10
yagoolar's Avatar
Yes. Already written it above. Yet there might be wiring fault of the socket of MY amp which result in such a behaviour of HP1000.
Meaning of an output's "load impedance"? pedrito Analog Line Level 3 30th June 2009 07:58 AM
Beyerdynamic's Headzone headphone promise "perfect spatial impression" Nordic Headphone Systems 1 28th August 2007 09:10 PM
What is the cause of "pre" echo? lgreen Music 4 31st August 2006 12:08 AM
Effect of cross-coupled "local" FB on plate load of previous stage ray_moth Tubes / Valves 23 27th April 2005 08:55 AM
"Digital" headphone amp from Crystal/Cirrus peranders Headphone Systems 0 19th April 2002 07:36 AM
Copyright ©1999-2017 diyAudio
