| Headphone Systems Everything to do with Headphones |
Hey guys,
Haven't posted much of my new stuff, so here is one of my last projects. It is a really nice headphone amp. The technical performance is the best I have ever seen in an audio device, the waveforms look so good! Balanced output is cool too, but the headphones need re-wiring. I will have to post some scope screenshots sometime, without HP filter in place I can amplify orders of magnitude higher frequencies than audio nicely! Just a nice chip for more than audio. I have regulated supplies +/- 15V supplies, with inductive LP filtering on power input and regulated output. Nice low-ESR power stiffening, Elna Silmic 2 on the input. Thin film 0.5% low noise resistors thoughout, and OPA2134 op-amps (x2 per channel). You can see I use mono-bloc style construction with seperate PS and PCB for each channel. I have BNC connectors for input and output, and a stepped attenuator using a piano-dip switch. I can post the PCB if anyone is interested. -Matt |
#2 |
New camera, I tried to get artistic but I need some more time
#3 |
more
#4 |
overall, little blurry
#5 |
an artful attempt
#6 |
I would have a difficult time with the SMT procedure,
can you post a schematic please? Did you build one without the surface mount components to test the circuit? Thank you........ |
#7 |
I can add a schematic if I get time to draw one later.
I winged it and just designed a PCB for this one, I made one small error though. I have already revised the PCB to correct it. I didn't use through-hole because with the high-performance stuff there is no advantage to it. SMT soldering is a skill worth learning. There are superiour parts available in the SMT packages, and these are 0805, which are not that hard to solder anyway. Just a week ago I took two total soldering newbies through SMT assembly with a little kit I made for a class-D amp. By the end of the assembly they were suprisingly proficient. -Matt |
#8 |
yep, eagle files would be nice
#9 |
Perhaps a video we could download to teach SMT installation and
repair. I have been told for three quarters the an SMT seminar was comming to our school but it never happened and I graduate in June. Thank You. |
#10 |
I use P-CAD but I can post gerbers.
There are several SMT tutorials on the web, might try a search? -Matt |
| Balanced Reference Headphone Amplifier in | semola | Headphone Systems | 1 | 23rd March 2009 08:30 AM |
| FS: Headphone amp PCB TPA6120+OPA2134 | mravlcax | Swap Meet | 0 | 25th January 2009 02:43 PM |
| TPA6120 headphone amp with servo | nelsonvandal | Headphone Systems | 3 | 8th November 2007 07:54 PM |
| SONY MDR-CD370 Digital Reference headphone FOR SALE! | cartman | Swap Meet | 0 | 17th July 2005 09:02 AM |
| tpa6120 New TI High Quality Headphone Amp | Algar_emi | Headphone Systems | 6 | 3rd July 2004 10:44 AM |
