Headphone Systems Everything to do with Headphones
MOSFET follower headphone amplifier
Old 7th October 2010, 11:51 AM   #111
xnor is offline xnor
xnor's Avatar
Thanks Patrick,
as I don't know too much about this stuff I have more (stupid) questions.
Could the output impedance reduced further?
It looks like this thing needs a "beefy" power suppy. Does the follower also work with lower voltages, think of batteries, i.e. a scaled down version?
Old 7th October 2010, 01:28 PM   #112
EUVL is offline EUVL  Europe
> Could the output impedance reduced further ?
No.
> Does the follower also work with lower voltages, think of batteries.
It will work at 12V. You probably want to drop the diode voltage to 6.2V anyway if you are using 2SK2013. It will still consume approx. 200mA per channel.
Patrick
Old 9th December 2010, 09:23 PM   #113
zebra100 is offline zebra100  United Kingdom
Originally Posted by adason View Post
i built this one quite a few years ago, it worked fine, but in comparison to tube headphone amp it was nothing special
http://headwize.com/projects/showfil...szeke1_prj.htm
I built the updated design (using a three terminal adjustable voltage regulator (LM317T) as a constant current source). I used an off board 13.8v regulated PSU, and an Alps Blue 50k dual log/47k metal fim shunt resistor as a passive attenuator for the input source. It sounds surprisingly detailed and uncoloured.
Old 20th February 2011, 09:45 PM   #114
diegomj1973 is offline diegomj1973  Argentina
diegomj1973's Avatar
Hola a todos!. Soy nuevo en este foro. Soy de Marcos Juárez, Córdoba, Argentina. Quiero compartir con ustedes un circuito de mi propiedad que diseñé hace un tiempo y que tiene un desempeño ejemplar. Es un buffer basado en mosfet (drain común) trabajando en clase A pura y es single ended. Puede desarrollar una potencia máxima de hasta 1,26 W rms sobre 6 ohmios. Actualmente lo utilizo conectado a la salida de un CD player con voltaje de salida de hasta 2V rms, con lo que logro potencias de hasta 0,66W rms sobre 6 ohmios. Dispongo toda sus especificaciones técnicas para quien desée construirlo.
Saludos y disculpen mi idioma.
Old 20th February 2011, 10:06 PM   #115
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
diego, english please
I translated your other post, with a note to post in english
maybe you did not read
I know your text is fine
but I cannot continue to translate all your posts
next non english post will be removed
moderation
Old 4th March 2011, 09:04 AM   #116
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Hello everyone!. I'm new to this forum. I'm Marcos Juárez, Córdoba, Argentina. I would like to share with you a circuit of my property that I designed some time ago and has an exemplary performance. It is a buffer based on mosfet (common drain) working in pure class and is single ended. You can develop a maximum power of up to 1.26 W rms on 6 ohms. Currently I use connected to the output of a CD player with output to 2V rms voltage, which accomplishment powers up 0, 66W rms on 6 ohms. I have all the technical specifications for whom wish build it.
Greetings and sorry for my language.
Old 4th March 2011, 09:06 AM   #117
moderation
tinitus if you want when diego post in spanish send me a pm or e-mail & I will translate for the forum.
Cheers
Felipe
Old 16th July 2011, 07:17 AM   #118
Dr.H is offline Dr.H
have hd555 and keen to build this but is there an alternative to lu1014?
Old 18th July 2011, 08:42 AM   #119
Not really, but then it is very easy to get, prematched.
Search Results
Patrick
Old 18th July 2011, 08:43 AM   #120
thanks Patrick, is this still considered the top headphone amp for diy?
MOSFET follower headphone amplifierHide this!Advertise here!
mu-follower hybrid headphone amplifier rjm Headphone Systems 12 4th January 2010 08:45 AM
headphone amplifier = tube + mosfet sparkle Headphone Systems 25 23rd June 2009 02:52 PM
single mosfet headphone amplifier question Jean Headphone Systems 8 23rd June 2007 11:50 PM
darlington/mosfet in emittor follower / headphone amp svokke Headphone Systems 11 8th June 2005 06:19 PM
Mu follower, headphone amp? alk Headphone Systems 6 29th July 2004 04:23 AM
