Headphone Systems Everything to do with Headphones
Headphone amp with tube PS
Old 28th January 2007, 06:28 PM   #11
Phergus_25 is offline Phergus_25  United States
Send a message via AIM to Phergus_25 Send a message via Yahoo to Phergus_25
Thanks so much for all your help.
I'm a relitive tube novice, so I dont exactly get what I need to do with some of this, but I am trying to figgure it out.
Old 28th January 2007, 08:35 PM   #12
Ok, Im getting a better grasp on this.
So in the PS I will need two 5u4g rectifier tubes, and a transformer, From what I read Im going to have to deal with heaters outside of the main circut, so what do i do to deal with that?
Also I understand that I will need to slightly modify the PCB so that i can run it to produce high current. Is there a thread that shows that alittle more or am I going to have to get it all from the link already provided.
I plan to start this pretty soon, though I could see it taking a month or so to get it all done and then more to case it.
-greg
*Edit*
I think that part of my slight problem is im not completely sure how to read every part of the schematic, mainly where the tubes and transformer come into play.
Im reading a tutorial on that right now.
Old 28th January 2007, 11:35 PM   #13
never mind the 9 pin seems to be the way to go.
Old 28th January 2007, 11:57 PM   #14
kevinkr's Avatar
Something that all of these designs seem to have in common is the use of a large electrolytic cap with 100V or more sitting on one side and a pair of headphones sitting on someone's head on the other.
I designed and built a white CF driven by an direct coupled SRPP based on this approach and haven't had a problem.. (So far) Still I can't recommend this for safety reasons and broach that concern here.
Under some circumstances this could be a potentially hazardous approach to one's hearing and a possible shock hazard as well if something were to go wrong. Should that cap fail abruptly the pop in one's exploding headphone driver could be deafening, and should the headphone cup not be adequately insulated it could be a shocking experience as well.. (A small autoformer on the output would remove this concern and provide some impedance matching as well.)
Not to make light of all of this, but a small, super high quality output transformer from the likes of Hashimoto (etc) would be a lot safer.. Something along the lines of a 71A driving a 5/7K transformer would make a very nice and much safer headphone amplifier.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th January 2007, 12:17 AM   #15
Iv though of using out put transformers before, and like the idea. Expcially since I could match the 50 ohms of my headphones so well.
How much would I have to expect to spend to get a decent set of output transformers tho?
-greg
Also, isnt the risk of a cap failing in such a manner incredibly low? and couldent this be fixed with some output fuses?
Old 29th January 2007, 07:36 AM   #16
Stixx is offline Stixx  Germany
Stixx's Avatar
No, you will need one psu shown and split up after the last C...
For clarification I've attached the schematic of an aikido how I was planning to build it...It is the high impedance version since I am using Senn's, but it gives you an idea how to build a psu.
Reading a lot for sure helps, and getting PSUD2 to fiddle with parts values, different layouts and so on...
You don't have to modify the PCB...get the noval PCB from Broskie and stuff the parts according to YOUR schematic.
Kevin, I understand your worries...but I don't necessarily agree as long as the output caps are quality ones...
I am using Siemens mkv in my C3G headphone amp, and those are virtually indestructable and do sound much better than cheapo electrolytics!! They are quite large though...
Oliver
Old 29th January 2007, 08:26 AM   #17
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
I got a pair of electra-prints custom wound for about $200. You can also try Hammond 119DA's in this application. You would need to design around them, but they are only about $20 per. Another option is to parafeed and pick up a pair of Speco T-7010's. These are about $4 per. I am working on a board for this, but I won't be done with it for a few months, but the plan is an all tube parafeed headphone amp that can be built for under $120 or so. Seemed like a hole in the "available" projects.
Yes, but in the cost benefit analysis, you need to consider the other side too. That is, while the probability is low, do you want to trust your hearing, and perhaps your life, to a cheap capacitor? Sometimes they are not made right, sometimes they see too high of a voltage, or too much heat, and sometimes they just get old. All sorts of things can go wrong.
Transformer coupled amps sound better anyway. OTL if is for chumps
Didn't Bas do a transformer coupled Aikido for headphones? I seem to remember something about that. Maybe a forum search will turn something up.
-d
Old 29th January 2007, 08:29 AM   #18
dsavitsk's Avatar
But he is using 50ohm phones, which means 6 or so of these in parallel per side to get a decent corner frequency.
Old 29th January 2007, 11:26 AM   #19
Thanks for the new onslaught of info. I was hoping that you, dsavitsk, would jump in here.
I would be cool with trying out a transformer coupled amp, even if I had to do it with P2P, that is if I can at some point get a grasp on the design aspect of things.
When looking at the 119DA I am seeing 600 ohms, 4 and 8. Im sure its a simple matter, but ow would i impedence match that to 50? Or am I mis understanding this situation?
thanks
-greg
Old 29th January 2007, 12:19 PM   #20
Stixx's Avatar
Well, 600 divided by 8 equals 75.
75 times 50 (your headphones) equals 3750, pretty much the primary resistance the schematic wants to see...
The rest I'm leaving to dsavitsk...
Headphone amp with tube PSHide this!Advertise here!
Tube Headphone Amp sorenj07 Swap Meet 6 12th February 2008 02:35 AM
Tube Headphone Amp? Dougie085 Headphone Systems 22 3rd November 2007 09:10 AM
Octal tube as headphone amp output tube yagoolar Headphone Systems 6 25th November 2006 09:11 PM
My new tube headphone amp MCLL Headphone Systems 7 24th July 2005 08:44 AM
How to use one tube instead of another in this headphone amp? Pentium100 Headphone Systems 5 17th January 2005 03:00 AM
