Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 29th October 2006, 02:48 AM   #1
diyHerb is offline diyHerb  United States
Default Headphone amp from Audiodigit 2020?
Hi there,
I'm a newbie - haven't soldered anything and have limited knowledge...
I ordered a Audidigit 2020 (http://www.audiodigit.com/index.php?section=35) a while ago and have never used it. Now I want to get into good headphones. I was wondering if I could set this up as a headphone amplifier?
If so, how do I go about wiring the speaker connectors to the headphone jack?
Thanks,
Herb
Old 29th October 2006, 05:56 PM   #2
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Send a message via Skype™ to VEC7OR
Well class D is not actually what you want with good headphones, class A is the best you can get for them.
I think that simple 4 opamp amp will put class D to shame with headphones.
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 29th October 2006, 10:47 PM   #3
Herb,
The TA2020 chip has bridged outputs so I don't
think they will work with headphones (which have
a common ground for both channels.)
You may want to have a look a the many
headphone amplifier projects here:
http://headwize.com/projects/index.htm
There's also an excellent page on building the
cmoy headphone amp:
http://tangentsoft.net/audio/cmoy-tutorial/
Dennis
Old 29th October 2006, 11:15 PM   #4
fokker is offline fokker  China
I am not sure why one would need class D as headphone amps. you can get a simple class A with a few resistors and capacitors to drive pretty much any headphone to ear-splitting levels.
Why class D?
Old 30th October 2006, 01:43 PM   #5
Thanks for the responses. I'm totally new to this and did not realize it was not suited to the task. I had it lying around unused and thought icould put it to work.
I'll explore Class A. Thannks.
Herb
Old 31st October 2006, 01:41 AM   #6
Why class D?
I have done a few class-D designs, both for headphones(400mW or so) and for normal speaker (50-100W range). The biggest reason behind class-D for headphones is efficiency. Since headphones are used in battery operated devices a lot of time, more efficiency = longer battery life.
Hope that helps.
By the way, im curios as to what a "good" spec is for headphone amplifier. The prototype I made was 100dB of DNR and 0.03% THD+N @ 137mW (32 Ohm load) and 0.15%THD+N @ 446mW (8 Ohm load). Im wodering if anyone out there has any insight on whether this is a good performance or not.
Old 31st October 2006, 06:50 AM   #7
starn02 is offline starn02  Italy
Wink Just take a look at the AudioDigit's website
Well ... you asked for it .. and it looks like it's coming ;-)!
See the announcement of the "TubeHead" tube headphone amplifier ... looks very promising!
Old 31st October 2006, 06:51 AM   #8
Sorry, I forgot the link:
http://www.audiodigit.com/index.php?section=26
Autocostruire/Audiodigit 2020 Puffin Class D 0 3rd March 2007 03:33 PM
FS: Audiodigit 2020 diyHerb Swap Meet 5 8th February 2007 04:27 PM
Audiodigit/Autocostruire 2020 amp Puffin Class D 1 4th July 2006 01:33 PM
Audiodigit/Autocosctruire 2020 amp Puffin Class D 1 11th June 2006 10:13 AM
FS AudioDigit- 2020 T amp module ianfromnotts Swap Meet 4 4th June 2006 05:54 PM
Page generated in 0.09882 seconds (79.20% PHP - 20.80% MySQL) with 10 queries
