OTH -> One Transistor HeadPhone - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 8th September 2006, 03:41 PM   #1
mod_evil's Avatar
Send a message via MSN to mod_evil
Arrow OTH -> One Transistor HeadPhone
This is a scheamatic without gain, for Head-Phone or BUFFER use.
This is a PURE Class-A schematic without FEEDBACK!
This is my frist design in pure class-A for HeadPhones.
Old 9th September 2006, 04:34 PM   #2
sparkle's Avatar
hey - this look nice - maybe to try to use it with dual power supply - in that way you will not have the need for the output capacitor.....i don't like them (sorry) - but hte amp is nice - it should work nice for low frequency load ......
right?
have you try it allready
how it is sounding
regards
daniel
Old 9th September 2006, 04:46 PM   #3
mod_evil's Avatar
I haven't it allready.
It is only a simulation to in the future I make them.
I need to evaluate this circuit to make a very very good head-amp. =]
Best Regards,
Felipe
Old 9th September 2006, 07:48 PM   #4
Hi Felipe,
I built a headphone amp like this a while back (but I did have a bit of feedback).
I started with an emitter follower, like yours but on dual rails, and then replaced the emitter resistor with a current source. It made quite a difference, and is really worth trying.
Then I changed the one transistor with two in a complimentary feedback pair, and that helped as well, but it did introduce feedback.
I drive my grados with it and I'm really pleased with it.
I totally agree that, you don't need voltage gain to drive headphones, more a buffer to provide the current, and relieve the source.
Phil
Old 9th September 2006, 07:56 PM   #5
mod_evil's Avatar
I'm thinking to drive mine headphones with this new circuit:
http://www.diyaudio.com/forums/showt...postid=1001572
A buffer with 6sn7GT and a HEAD-AMP.
Best regards,
Felipe
Old 13th September 2006, 03:57 AM   #6
suiraMB is offline suiraMB  Norway
Try using an LU1014D power JFET as the active device instead, and replace the load resistor with another LU1014D. And put the rails at +/- 12V.
That is:
Lower JFET - drain to output, source through a small resistor to negative rail, gate to negative rail.
Upper JFET - drain to positive rail, source through another small resistor (same value if the devices are matched) to output, gate to input.
If you want some feedback, use a 10K resistor in series with the input, and a 100 ohm resistor from the output to the gate of the active device.
With proper matching, the DC offset should be negligible (meaning no coupling cap), and distortion negligible. A 3 ohm source resistor would give about 500mA bias at +/- 12V rails.
Then you can drive a low-impedance headphone as well. Either way, the performance should exceed that of the bipolar.
For high-impedance headphones, the 2SK389V (or LSK389C) should perform admirably with a 75-300 ohm source resistor.
"Do not attempt to stop this cicular saw with your hands or genitalia." - Warning Label
Old 13th September 2006, 01:53 PM   #7
mod_evil's Avatar
Suira,
I can't buy a LU1014D, because I can't import this in Brazil. I haven't international credit card to buy it.
And... IF I PUT a IRF610?
In what circuit design software can I simulate mosfets? I have the circuit maker professional and I can't simulate mosfets in this =[.
I have changed the 1000ohm resistor to a CCS with 2 BC549.
Thanks,
Felipe
Old 13th September 2006, 05:00 PM   #8
Ah. That's a pity. You may want to keep an eye on the "Lovoltech Group Buy" thread, then.
The IRF610 is not a depletion mode device, so it will not self-bias like the circuits I suggested. Also, it is a MOS FET, not a JFET, so its transfer characteristics are different.
You could try LTSpice, Orcad, etc.
Though with such a simple circuit, it will probably take less time to build it and listen to it.
That should give lower distortion, so probably a smart move
I would also suggest trying to build the circuit with a dual monolithic JFET, such as the 2SK389V (Toshiba), LSK389C (LIS), 2N5911 (Vishay), IF3602 (InterFET) or similar.
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Wanted 2paar beta matched transistor for my headphone amp! cartman Swap Meet 0 17th July 2005 08:51 AM
PPP transistor ? Colt45 Solid State 5 3rd September 2002 10:38 PM
Copyright 1999-2017 diyAudio
