Headphone Systems Everything to do with Headphones
Discrete Single End TRUE Class A HeadPhone Amplifier
Old 6th September 2006, 09:42 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Thumbs up Discrete Single End TRUE Class A HeadPhone Amplifier
Hello lovers of diyAudio
My Headhone Amp project
for you?
Schematic and detailed description is a part of
Destroyer X very good topic:
http://www.diyaudio.com/forums/showt...007#post997007
Enjoy da Musica!
Here is my lineup original idea,
with Component layout of my circuit
( please respect my full copy right to this amplifier )
lineup
Old 6th September 2006, 10:24 AM   #2
sparkle is offline sparkle
sparkle's Avatar
only to be more confortable to look and read - here is the sch from that thread.....
it will make a very nice amp for small headphones or Grado's - much better than what i was using to play with.....
Old 7th September 2006, 12:35 PM   #3
sparkle's Avatar
o.k. - to keep this thread allive - it will be a pitty to loose it so quickly - nice small amp ....
i have drawn a clearer schematic ...maybe lineup will correct me if i have made a mistake somewhere....
regards
daniel
Old 7th September 2006, 01:41 PM   #4
DorinD is offline DorinD  Romania
DorinD's Avatar
What could you say about the thermal drift which is essential for an A class amplifier?
I said that because the current through BC557 (and so on) seems too sensitive by temperature for my taste. Have you sense any change in sound over some time of continous functioning?
Old 7th September 2006, 02:22 PM   #5
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Despite Line up....this circuit is very interesting..i am very interested.
My resistance to construct it immediattely is because the power consumption.....as i will have to produce a supply, and this means that will not be portable anymore...attached to the mains...hummm...not good to MP3 player...as will need to be fixed.!
I am thinking to reduce voltage and current, to recalculate the whole thing to lower voltage transistors, and to use Nickel Cadmiun batteries, and i have a lot of them..all brand new..costed 1 dollar each one...950 miliamps each unit..AA sized.
The circuit may sound very good, as it is simple and class A...and with differential that we can try to make better that feedback line.
Yes...batteries may be noisy...but we can try to filter that noise.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 7th September 2006, 02:34 PM   #6
sparkle's Avatar
Dear DorinD,
i am sorry but i did not build this little thing...it is entirely made by Lineup....he will be back in a couple of days and i am sure that he will answer Your question....
I assume that You don't have to worry because he made it and he reported that the sound is simply wonderfull.....
best regards
daniel
my dear Carlos....i am happy that you are interested in this amp....yes i agree with you that the consumpiton is a little bit to much for the batteries...but i have a small transformer in my home that has (i think) the proper voltage needed for the amp and the transformer is not to big....i think this still can be preety small for class A...small enough to be used with my laptop....
i am looking forward on what you will do...(smaller fo the batteries) - but i am courious if this will destroy some of the magic - maybe it will.....
regards
Old 7th September 2006, 05:39 PM   #7
sparkle's Avatar
Default some more information
o.k. guys....
i have received a very nice mail from the guy that started this thread (thanks lineup for the kind words).....
i will quote him - it is the best.....
about my amplifier:
you see the load is 100 Ohm.
In fact the omtimal load for this type of class A is
resistors = headphone impedance
this will give maximum output power
and this means, setup is also the best QUALITY low distortion
performance
when load is = resistance in output stage
My output stage, is in fact compromise,
for amplifier to be good form 32 - 300 Ohm headphones
100 Ohm is in middle*!
formula:
if LOW = 32 and HIGH = 300 Ohm phones, you want to use
square root( LOW x HIGH ) = 97.79 Ohm
so, if you want to make special version for 32 Ohm
and lower voltage, it can be done
no problem
only some matematicals and some thinking
and some little changes
lineup
best regards and happy diy
Old 1st October 2006, 09:19 AM   #8
lineup's Avatar
Smile thanks sparkle
sparkle
thanks for your schematic clean-up
http://www.diyaudio.com/forums/attac...amp=1157628903
Just for fun
here is how an electronics program wants to arrange PCB layout.
I wouldnt build it like that.
I have shown a drawing in a previous post here,
my idea of a perfect placing of components onto a board.
Anyway
here is the computed suggestion
from a good but a bit stupid electronics program.
You know such programs, just like some people,
have very low ability to think out of the box
Newbies and audio beginners, still have plenty of this quality.
As they are not yet inside the square and improved box of accepted audio ideas.
This is one reason, I like so much to exchange ideas with new diyAudio members.
Good for my creativity
lineup
lineup
Old 1st October 2006, 09:46 AM   #9
Default Your ideas are rigth and i apreciate them very much
Good analisis and evaluation of some people behavior...... they are exceptions....not a rule.
Your posts are different....better in my point of view, as they show that there's a human being in the other side....not a computer terminal writing things...a real man in the other side.
One added to one will be not always two..... if those ones constitute a couple.... married persons...this can result in three, four, five or more...including the kids....in electronics can be applied to many things...including harmonics.
A little bit more flexibility using the brain, is more than adequated.
Sparkle is sick...he is facing a storm in his life, i am not sure if he will be able to answer you Lineup
regards,
Carlos
Old 2nd October 2006, 10:33 PM   #10
lineup's Avatar
Default Re: Your ideas are rigth and i apreciate them very much
regards,
Carlos
Very sorry to hear this, Carlos.
He was very understanding and helpful to me, when I started this topic
and was waiting in house-arrest for 10 days.
Planet10 was also a great comfort to me. Dave is alright.
Hope things will get better for Sparkle.
As far as I can tell, our friend does not deserve to be not happy and feeling bad.
regards
lineup
Discrete Single End TRUE Class A HeadPhone AmplifierHide this!Advertise here!
Discrete Class A amplifier for discussion. keantoken Solid State 11 17th January 2009 05:22 AM
Single ended headphone amplifier audiodesign Headphone Systems 15 11th December 2008 06:48 PM
Mini Portable Headphone Amplifier, with Discrete Diamond Buffers cetoole Headphone Systems 3 30th May 2006 07:32 AM
Copyright ©1999-2017 diyAudio
