| Headphone Systems Everything to do with Headphones |
diyAudio Moderator Emeritus
This is a continuation of the idea that originally formed in this thread: http://www.diyaudio.com/forums/showt...463#post945463
After a little thought, the design could be quite simple. The high side would have a pnp connected to the rail and the inductor, its base connected to the collector of an npn through a resistor. The emitter of the npn would be grounded, and the comparator would drive the base through a resistor. Mirror that for low side (using npn's instead of pnp's and pnp's instead of npn's) and it should be very simple to build. The output stage parts would include 2 pnp's, 2 npn's, and 4 resistors. The comparator would be an IC, and the feedback loop/input parts would include 3 resistors and a capacitor. That could be a bare bones implementation. I'll try to draw up a schematic and maybe come up with some part values a little later tonight. Everyone feel free to list what they'd like to see from a class d headphone amp!
Brian |
#2 |
This is an interesting project, should be fun to see and hear what comes of it.
Let me play Devil's advocate here, to give the design team some things to think about. 1) Input buffer. Most Class-D amps use an input buffer before the modulator. And what is that buffer? An op-amp! You can make a darn good, easy and cheap headphone amp with the right op-amp. Is the Class-D power stage going to sound better than the op-amp buffer? Think about that. (The buffer does not need to be an opamp, BTW). 2) RFI. Looks like we will go with a non-bridged design? That means the potential of a full power radio frequency square wave applied to the phones. You'll need to get that filter just right. Probably a 2nd order filter, at least. Post filter feedback? 3) Noise. Switching amps are noisy. But the noise is far enough down that it is not, or almost not, audible on regular speakers. Headphones are much more sensitive. Noise is likely to be a big problem.
Take the Speaker Voltage Test! |
#3 |
The only practical benefits of a class-D headphone amp are efficiency and portability, so a 5v volt max swing might be acceptable.
If it is, why bother with a discrete output, a few paralleled CMOS gates will give you an output stage with plenty of current capability, FAST transition times, and a high impedance, couple hundred pF, input impedance. |
#4 | |||||
+/-5V rails with a single ended amp will allow a maximum of 5.9mWrms output power into 600ohms, and that's assuming you have full rail-to-rail swing. That figure increases to 110mWrms for a 32ohm load. Not much power for high impedance cans, but it could probably work well for lower impedance cans. Quote:
Brian |
#5 |
Account Disabled
You don't need an op amp buffer at all, just drive the comparator directly.
You dont' need a 4'th order filter, just more junk to pollute the signal path. Keep it simple, keep it pure, keep it clean.. it'll pay off. That's alot of the magic behind the UCD in the first place, remember? |
#6 | |
We may not need a 4th order filter, but if it were inside the feedback loop then it wouldn't pollute the signal path. I'll draw up my idea for the 4th order filter w/feedback and post it here to see what you guys think. For now, here's a schematic of what I had in mind. If anyone has suggestions for improvement, or suitable devices, please say so. I used the LT1016 part for the comparator because it readily available in eagle and would probably work ok with this design. Any other comparator could be used, and with the way the output stage is set up, it doesn't need to have high voltage supply capability. In fact, the comparator just needs to be able to work with split rails that could even go down to +/-2.5V as long as it can drive it's output close to the rails and sink and source a couple mA of current. You'd just need to change the base resistor values for R1 and R2. Furthermore, the +/-12V rails could easily be regulated down to the correct voltage levels for the comparator. That would also help reduce noise getting into the comparator through the supply.
Brian |
#7 |
Here's the schematic with the 4th order filter implementation. I have no idea if this would actually work though.
The other interesting thing to note with this design is that the bipolar transistors could easily be replaced by FETs, which would lower the power dissipation in the base/gate resistors. Then again, the power dissipated in the resistors would depend upon the required base current which depends on the current gain of the transistors.
Brian |
#8 |
Hey Brian,
Looks nice and simple. I don't know enough about the UCD stuff to know how well it would work. The 4th order filter will remove a lot of the switching carrier, that's good. The Super-T uses a 4th order (two 2nd order in series, actually) and there is very little RF on the outputs. Don't forget that this filter will not do much to attenuate AF noise - and there will be LOTS of AF noise. Just connect a pair of headphones staight to a T-AMP if you want an example. (Beware your ears and the phones!!) So what would be the advantage of this type amp over a small Tripath chip running at 9 or 10 volts?
#9 | ||
#10 | ||
The advantage of this type of amp over a small Tripath chip would be that you have single ended outputs so you can connect the output grounds, you can have a higher switching frequency for easier filtering, and theoretically you can have a load independent frequency response for use with widely varying loads. Simplicity, size, and cost would also be lower with this type of design. Quote:
That 5.9mWrms figure was maximum output power, you wouldn't actually run the amp at that level for good sound. Realistically, you would be running it at less than a mWrms output, so a digital logic CMOS buffer wouldn't be totally out of the question! I'd love to see something like that too, but can't think of an easy way to implement it at the moment.
Brian |
| Type 46 as voltage amplifier | abj1 | Tubes / Valves | 6 | 29th January 2005 05:34 AM |
| Capacitor type for simple headphone amp | GianLorenzo | Headphone Systems | 3 | 20th December 2004 08:45 AM |
| Chip (gainclone?) type headphone amp | Vladco | Headphone Systems | 14 | 21st June 2003 04:31 AM |
| Page generated in 0.16270 seconds (78.49% PHP - 21.51% MySQL) with 11 queries |
