DIy tube-headphone amp (only 1 channel) - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 2nd May 2006, 05:00 AM   #1
jarthel is offline jarthel  Australia
Default DIy tube-headphone amp (only 1 channel)
well it was been working fine in the past and suddenly, only the right channel has sound. I've change all the tubes so I somehow doubt that is the problem.
I measured the voltage across coupling out capacitor (470uF 350V in the schematic) and I'm getting +100V for the working right channel and +200V for the non-working left channel.
I am not really familiar with "debugging" circuits as this is not my area of expertise. Any help is appreciated.
Thank you very much for the replies.
ps.
I have attached the schematic.
Old 2nd May 2006, 05:45 AM   #2
rpapps is offline rpapps  Antarctica
Hi Jarthel
The 200 volts you have measured suggests that the lower half of V2 is not conducting. My first suspect would be R5. Have you compared the other voltage readings on the circuit?
Cheers
Rob
Old 3rd May 2006, 12:37 PM   #3
kskr is offline kskr  Hong Kong
Do all filaments light up?
Kenny
Old 4th May 2006, 02:08 AM   #4
Originally posted by rpapps
Hi Jarthel
Cheers
Rob
have not done so yet. will do this weekend.
Kenny
yes. all the filaments light up as far as I can tell. I think there are 4 wires that light up.
Maybe it's not 4. But I'm sure all 3 tubes have the same no. of filaments that light up.
Thanks for the responses.
Old 4th May 2006, 06:34 PM   #5
Hi Jarthel,
According to the schematic, you may want to check the V1 tube plate voltage first (right after the R2 where the schematic says "108V")
And check the voltage at bottom where the schematic says "2.5V"
also.
I'm not a pro but hope I could help anyway.
Kenny
Old 5th May 2006, 04:23 PM   #6
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Can you drop in an ECC82 orECC81 into that circuit?
Old 13th May 2006, 01:34 PM   #7
thank you all for the help.
I had the time to look at the problem closely yesterday and it seems the left channel ground wire got loosed. :|
IFR513 headphone amp channel mismatch zebra100 Headphone Systems 1 20th May 2009 03:10 PM
1 watt per channel tube headphone amp Sal Brisindi Headphone Systems 6 6th April 2007 12:05 AM
2 channel headphone amp impsick Headphone Systems 9 18th February 2007 03:21 AM
Octal tube as headphone amp output tube yagoolar Headphone Systems 6 25th November 2006 09:11 PM
KG headphone amp, one channel... L Daniel Rosa Swap Meet 8 19th October 2002 11:51 AM
Copyright 1999-2017 diyAudio
