Headphone Systems Everything to do with Headphones
Headphone amplifier
Headphone amplifier
Old 1st March 2006, 06:05 PM   #1
audiofan is offline audiofan  Canada
Default heahphone amp
I would like to build an heaphone amp and I have desing this circuit with parts I have, does somebody see big flaw in this desing
Old 1st March 2006, 06:08 PM   #2
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Headphone amplifier
I am not an expert in solid state but i think that 30V supply is more than enough to blow your ears+headphones.
Old 1st March 2006, 06:37 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: heahphone amp
you have something good going here
very interesting idea!
Three things:
1. Better use N-JFET. Much much easier to find. Better price.
I also think generally speaking, N-JFET are better peformance than P-JFET.
You simply have to turn a few thing upside down in your circuit.
But can keep most values the same.
2. Only a few uA operation in JFET.
I do not think it will work well at such low current level.
At least 0.2 mA, maybe you need even 0.5-1.0 mA for good linearity.
To set current in JFET, you use a resistor B-E (Base-GND) at T3.
2k2 will give ~0.3 mA in JFET.
At same time this change would make ( 10k x 0.3 mA = ) 3 Volt drop across R10.
And so you would need to adjust DC voltage at JFET gate.
Change R8/R9 a bit to get output at 15 Volt.
3. Choice of transistors in output. TIP29/30.
I do not remember how much power they are for. But you will not often see them.
Think they are slow.
I am sure they will work alright, if you have no other.
But There are better choices.
- Often used for lower power audio are TO-126 case: BD139/140 or MJE340/350.
- Think also MJE15030/15031 (TO-220 case) could do very nicely.
Good circuit, after a few changes!
lineup
Old 1st March 2006, 07:00 PM   #4
2K2 across T3 does wonderfull thing high frequency limit has almost double and square wave respose is a lot better...
i will work tomorrow on going to a n chanel fet...tank you
Old 3rd March 2006, 02:31 PM   #5
still in progress...............
will order parts semiconductors next week
Old 3rd March 2006, 03:43 PM   #6
lineup's Avatar
C5, you can and should attach in a more usual place.
Can be like 50-220pF, between B and C of T12.
Start with a value of 100pF.
Between Base and Collector of voltage amplification transistor T12. ( In the VAS, volt amp stage ).
C5, compensation cap, will work as you have it now, across feedback resistor.
But most designers use it as I mentioned, locally across VAS transistor.
Schematic looks basically good now.
You have done a fine job.
As I can see it will work alright like that.
There might be only small final trimmings, changes to some resistor values.
To get the best possible performance.
If you want to see a similiar preamplifier, this will be 'DOZ preamp'.
By Rod Elliott at http://sound.westhost.com/
It is basically same idea as your amp. But no output stage.
Death of Zen Preamp.
Minimalist Discrete Hi-Fi Preamp - ESP Project 37
He also has a DoZ Headphone Amplifier. Project 70:
lineup
Headphone amplifierHide this!Advertise here!
DOZ Headphone amplifier gretzteam Headphone Systems 8 21st August 2015 07:50 PM
DOZ headphone amplifier Gomer Headphone Systems 14 29th October 2013 08:04 PM
headphone amplifier sparkle Headphone Systems 31 15th October 2007 11:33 AM
DIY headphone amplifier jesserparker Headphone Systems 3 31st August 2004 11:24 PM
OTL Headphone amplifier Thom Headphone Systems 10 4th January 2003 11:18 PM
