| Headphone Systems Everything to do with Headphones |
Has anyone used the Jaycar 12AX7 preamp kit as a headphone amp? What modifications were needed?
#2 |
Don't bother. You need a much gruntier tube for headphone use with lower output impedance. As a linestage the design is the biggest *** I have seen in ages (use a totally lacklustre tube with far more gain than you you could possibly use and then wrap ********* of feedback round it to get it back down to manageable levels). You would probably be far better off with solid state.
There are plenty of good tube headphone designs out there if you do a google or a trawl of the forum. regards pm |
#3 |
This would work if you could find high impedance (z = several K ohms) head phones and these headphones usually were not "hi fi" or you could try to find a suitable matching transformer to drive the more common lo z headphones.
As the valve pre amp has already coloured the signal, you could use a clean solid state amp to drive your headphones without adding too much additional colouration to the net result. Yes it does sound different in a nice way on the guitar and no it doesn't improve my playing ;o( |
| Headphone amp circuit for preamp use. | marchel | Solid State | 2 | 6th February 2008 10:11 PM |
| Add headphone output to preamp | whitelabrat | Headphone Systems | 2 | 24th January 2008 07:36 PM |
| CMOY headphone amp, can it be used as a mic preamp? | internecine | Headphone Systems | 3 | 25th September 2007 05:39 PM |
| Passlabs preamp as headphone amp- need help | needtubes | Headphone Systems | 3 | 16th February 2004 09:30 PM |
| SoZ balanced preamp as headphone amp | akira | Headphone Systems | 5 | 7th January 2002 08:40 PM |
| Page generated in 0.06462 seconds (70.32% PHP - 29.68% MySQL) with 10 queries |
