Headphone Systems Everything to do with Headphones
Digitally controlled preamp/headphone amp
Old 20th March 2006, 01:24 PM   #511
magnum_1 is offline magnum_1  Italy
I'm not able to insert one picture in a post!It seems so easy...boh..
Old 20th March 2006, 02:24 PM   #512
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Okay, I think you have two unrelated issues.
First, the short on the output isn't really a short. I think you have a bad PIC (no code) and the outputs are just at ground potential (no signal). New PIC on the way.
Your trafo wiring is also wrong for 220V primaries.
You should tie the black and red primaries together (and to nothing else), then connect your AC to the yellow and violet. The way you have it, you are providing 24V to the Kook. The VRegs shoudl handle that okay, but the relay is before the regs, and may have been damaged.
After you fix the wiring, listen for the relay clicking at power-up. If it does not click, I will send you a new one.
Old 20th March 2006, 04:59 PM   #513
Ok Brian,
I have explained badly: I have tie the black and red primaries together (and to nothing else) and I have connected AC to the yellow and violet. Therefore I measured 15.4-0-15.3 on secondary (green--red/brown--blue)to kookaburra.
I listen for the relay and I heard click (light sincerely)at power up
and nothing other....
Old 20th March 2006, 05:09 PM   #514
Excellent. PIC is on the way.
Old 20th March 2006, 10:33 PM   #515
neutron7 is offline neutron7  Canada
neutron7's Avatar
Brian your mail folder is full. i tried to reply to the "potential problem with kooka" mail saying that mine appears to be one of the non programmed ones. anyways the mail was bounced.
"The e-mail message could not be delivered because the user's mailfolder is full"
i had another question as well
are these the same relays as can be used on kooka?
http://cgi.ebay.ca/NEW-12V-OMRON-G6H...QQcmdZViewItem
Best regards
Neutron7
Old 20th March 2006, 11:00 PM   #516
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Yes, those are the relays used on the Kookaburra. Of course, you already knew that, right?
Btw Russ/Brian, Omeron?
The power of Science compels you!
Old 20th March 2006, 11:03 PM   #517
neutron7's Avatar
well they are slightly differently labelled ont he board to what ithe description is. just wanted to be sure.
now i see "100" on the components list thats good. ill use some of the relays for input selector as well.
Old 20th March 2006, 11:11 PM   #518
Russ White is online now Russ White  United States
Russ White's Avatar
The G6H-12(100 version is high reliability) are indeed correct for the kookaburra, but not for the Darwin, or the Joshua Tree. Those take the smaller G6K relay.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 21st March 2006, 11:19 AM   #519
Thanks. Fixed.
Incidently, any relay with that footprint will work on the Kook. I have a bunch of Zettlers that I got from surplus that work great. I think about all the big relay makers have one.
Old 30th March 2006, 02:30 PM   #520
Hello,
Problem resolved !!
The new PIC has arrived, I exchanged it, and now all is OK.
The Kookaburra works, and works fine!
Thanks you all.
Alessandro.
Digitally controlled preamp/headphone ampHide this!Advertise here!
