Headphone Systems Everything to do with Headphones
Digitally controlled preamp/headphone amp
Old 20th December 2005, 07:31 PM   #311
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Does a shorted capacitor do anything?
Old 20th December 2005, 07:37 PM   #312
doggy is offline doggy  Canada
doggy's Avatar
Do you mean from the 0r jumper to ground? A straight cap in the 0r jumper spot will not work at all for me;I tried a few different values. Brian I am happy, it's sounding good.
Just to inform; the pre was working all along with th 0r jumper in but I just wanted to see if I could match it better to my system.
doggy
p.s doing my xmas polishing; he..he..
File Type: jpg 2005_1220new-solid-state0008 (custom).jpg (36.2 KB, 877 views)
Old 20th December 2005, 07:49 PM   #313
Glad it's working and sounding good.
I just mean a 0-ohm jumper across the pins of a cap is shorting the cap, unlike a resistor that would send some current through the cap. I test would be to measuer voltage across the cap pins. Just curious.
Old 20th December 2005, 07:57 PM   #314
troystg is offline troystg  United States
troystg's Avatar
Current takes the path of least resistance, and there is NO voltage accross a short.
A cap accross a 0 (zero) Ohm jumper is non-existant.
Jumper to ground or V may have an affect, but accross (in parralell with) the jumper has none.
Sorry just Ohms law not mine.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 20th December 2005, 08:09 PM   #315
doggy's Avatar
It must be fooling myself again. There is definitely something flowing between those two points. It could be the"proud papa syndrome"-
cheers
doggy
Old 20th December 2005, 08:39 PM   #316
troystg's Avatar
cheers
doggy
Keep in mind that your 0 (zero) Ohm jumper may not be EXACTLY 0 Ohms..
But I would expect it to have to be off pretty far for a cap to be audible in that position.
Troy
Old 20th December 2005, 08:49 PM   #317
Russ White is offline Russ White  United States
Russ White's Avatar
Yes of course there is something flowing between those two points. There is meant to be.
A bypass cap will not do anything for you but a very small resistance (like the jumper provided) or a 1-4.7R resistsor just provides a bit of isolation.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 20th December 2005, 08:56 PM   #318
Russ White's Avatar
cheers
doggy
While the analog part of the circuit has dual rails the digital portions only have V+ and GND(0V) so a cap in place of the jumper effectively blocks all current to the digital circuity, thus causing it not to work at all. That is why it will only work when you have a small value resistor or a jumper there. The cap you added will always be swamped, and thus is doing you no good as the current will always take the easy path accross the jumper or resistor.
Good work! Very nice preamp. I hope you enjoy it.
Cheers!
Russ
Audio
Old 22nd December 2005, 01:58 PM   #319
Nordic is offline Nordic  South Africa
Nordic's Avatar
Ta Max.. that one looks perfect. I just ordered the parts...
Old 23rd December 2005, 09:15 AM   #320
Mr. Triatic is offline Mr. Triatic  Sweden
Mr. Triatic's Avatar
i upgraded my kookaburra preamp with a SMD headphoneamplifier, sounds great together with the Kookaburra!
www.joddla.net/audio/
Digitally controlled preamp/headphone ampHide this!Advertise here!
