Headphone Systems Everything to do with Headphones
Digitally controlled preamp/headphone amp
Old 18th September 2005, 08:18 PM   #21
Russ White is offline Russ White  United States
Russ White's Avatar
Hi M.
I am not exactly sure how to answer your question, but here is what I found in te PGA2311 datasheet.
SWITCHING CHARACTERISTICS
Serial Clock (SCLK) Frequency fSCLK 0 6.25 0 6.25 MHz
Serial Clock (SCLK) Pulse Width LOW tPH 80 80 ns
Serial Clock (SCLK) Pulse Width HIGH tPL 80 80 ns
MUTE Pulse Width LOW tMI 2.0 2.0 ms
Input Timing
SDI Setup Time tSDS 20 20 ns
SDI Hold Time tSDH 20 20 ns
CS Falling to SCLK Rising tCSCR 90 90 ns
SCLK Falling to CS Rising tCFCS 35 35 ns
Output Timing
CS LOW to SDO Active tCSO 35 35 ns
SCLK Falling to SDO Data Valid tCFDO 60 60 ns
CS HIGH to SDO High Impedance tCSZ 100 100 ns
That is from the table in the datasheet. on page 3
On page 8 there is more information on the serial port.
Thanks for looking.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 18th September 2005, 08:22 PM   #22
saltnpeppah is offline saltnpeppah  India
Hi Russ...
I was looking for this.
lemme see what i can do...
wish me luck...
~M.
Old 18th September 2005, 08:27 PM   #23
Russ White's Avatar
By all means! Good luck!
Audio
Old 18th September 2005, 10:49 PM   #24
Default Internal or not to internal
Hi Russ,
Just a small question. I was looking at your schematic, and realised you have not included a crystal.
If you are, what speed would you like it to run at? I assume 8MHz.
Please let me know.
Also, one small question. Instead of having a rotary encoder and stuff; have you given thought about a Digital Pot and IR(or RF ) remote?
thats all for now.
~M.
Old 18th September 2005, 10:54 PM   #25
Russ White's Avatar
Default Re: Internal or not to internal
Originally posted by saltnpeppah
Hi Russ,
Please let me know.
thats all for now.
~M.
Hmmmm...
Nope no chrystal intended. It should not be necessary I don't think.
The only human interface is from a 5K pot with the wiper read by the ADC to get my value for the PGA2311.
I have given though about the IR or RF, but I wanted to get this simple example working first.
In fact if I couldjust get the part to send the serial data to the PGA2311 I would be happy.
Thanks!
Audio
Old 18th September 2005, 10:55 PM   #26
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Hi Russ,
12F683 has an internal oscillator -- you also use the power supply for VREF.
These are wonderful devices to work with.
Russ -- as you know what you want to accomplish in VB perhaps using a BX24 from Netmedia would ease your implementation --
Old 19th September 2005, 03:02 AM   #27
Russ White's Avatar
Here is what I have so far, it compiles, butr I have not tested it yet.
Code:
#include <pic.h>
#define Clk GPIO4
#define Data GPIO2
#define CS GPIO1
#define POT GPIO0;
writeByte(int out) {
	int b = out;
	int i;
	for (i = 8; i > 0; i--) {
		int x = 1 << (i-1);
		if (b >= x) {
			Data = 1;
			b -= x;
		else
			Data = 0;
		Clk = 1;
		Clk = 0;
writeState(int val){
	CS = 0;
	writeByte(val);
	writeByte(val);
	CS = 1;
int getState() {
	GODONE = 1;
	while (GODONE){
		NOP();
	return ADRESH;
main() {
	ANSEL = 1;
	ADCON0=0b001110001;
	TRIS1 = 0; // make output
	TRIS2 = 0; // make output
	TRIS4 = 0; // make output
	CS = 1;
	while (1) {
		writeState(getState());
Audio
Old 19th September 2005, 03:33 AM   #28
Russ White's Avatar
More complete....
Code:
#include <pic.h>
#define POT GPIO0;
#define CS GPIO1
#define Data GPIO2
#define ZCEN GPIO3;
#define MUTE GPIO4;
#define Clk GPIO5
	int b = out;
	int i;
		int x = 1 << (i-1);
		if (b >= x) {
			Data = 1;
			b -= x;
		else
			Data = 0;
		Clk = 1;
		Clk = 0;
	CS = 0;
	writeByte(val);
	writeByte(val);
	CS = 1;
int getState() {
	GODONE = 1;
	while (GODONE){
		NOP();
	return ADRESH;
main() {
	int i = 0;
	ANSEL = 0b001110001;
	ADCON0 =0b000000001;
	TRIS3 = 0; // make output
	TRIS5 = 0; // make output
	MUTE = 1;
	ZCEN = 1;
	CS = 1;
	while (1) {
		for (i = 0; i <2000; i++) NOP();// delay
Audio
Old 19th September 2005, 09:51 AM   #29
mauropenasa is offline mauropenasa  Italy
R.I.P.
hmm, Russ,
No register setup (WDT,OSCmode,fuse set, etc...) ?
No start up MUTE delay timing (<20mS) ?
And, not use a continuos read-write loop.
In my soft, the write routine it is execute only if dac value != of previus data, for threshold to the minimum the PGA writing (Digital noise).
In the normal conditions, the PGA do not write...
The internal osc clock has to be to very low frequency, to reduce the troubles.
With my PIC12F675 I have used 4MHZ (only value), but if the PIC12F683 have a lower osc, use it...
PS: normally are used "byte" definitions ( 8bit data ), to the place "int" (16bit data) ,obviously with ansi C compatible... (because the PIC elaborates only 1 bytes to the time)
Ciao
Mauro
Old 19th September 2005, 01:03 PM   #30
Russ White's Avatar
Thanks Mauro.
Yes, I knew I still had a lot of work to do. Thanks for pointing me in the right direction.
Cheers!
Russ
Audio
Digitally controlled preamp/headphone ampHide this!Advertise here!
