Headphone Systems Everything to do with Headphones
Digitally controlled preamp/headphone amp
Old 15th September 2005, 01:17 AM   #11
jackinnj is offline jackinnj  United States
jackinnj's Avatar
1) all micro-controllers like to generate clock noise
2) the microcontroller control lines should be decoupled with a resistor.
3) the microcontroller should be turned 90 degrees counter-clockwise -- makes the layout a bit more rational.
4) if you are using decoupling caps, and mixing SMT with through-hole -- use SMT decoupling caps.
5) use a separate digital ground and analog ground
You will get there -- your enthusiasm demonstrates it.
Old 15th September 2005, 12:41 PM   #12
ALBQ is offline ALBQ  United States
Default Blazing a trail
Russ,
Have you seen the preamp thread in the chip amp forum or my posts on Headwize? May give you ideas as those designs from a microcontroller and digital volume control perspective, are the same.
Cheers -ALBQ
My PGA2310 design - thread on Headwize
http://mywebpages.comcast.net/gilles...A2310-REV2.jpg
Old 18th September 2005, 01:21 PM   #13
Russ White is offline Russ White  United States
Russ White's Avatar
Default Need some coding help.. Please!!! :)
I will have to devide this into a couple of posts to get the images in.
I have implemented the following PCB...
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 18th September 2005, 01:24 PM   #14
Russ White's Avatar
And stuffed it....
Audio
Old 18th September 2005, 01:26 PM   #15
Russ White's Avatar
It is based on this schematic..
Audio
Old 18th September 2005, 01:28 PM   #16
Russ White's Avatar
Ok, now where I need help. The controller is the PIC12F83 (which is what I have on hand) which has the necessary ADC. I just can't figure out how to write the code to send the serial data to the PGA2311.
Can someone please help me with the code?
This is my first PIC project and I am a total MCU n00ber.
I have the PICC Lite compiler and MPLAB, which is what I would prefer to use, but ASM code for MPASM is fine too.
Please help me figure this out.
Cheers!
Russ
Audio
Old 18th September 2005, 02:45 PM   #17
jackinnj's Avatar
I bet it's a PIC12F683 that you have on hand.
Microchip has resources (assembler etc.) which you can download from their site for programming this device -- but first you have to flowchart what you want the device to do. They also have code which you can cut and paste.
Frankly, I find that it is easier to use MELABs PicBasic Pro -- on their website www.melabs.com you can view the manual.
there is plenty of discussion to help you get started at http://www.picbasic.co.uk/forum/
Old 18th September 2005, 03:04 PM   #18
Russ White's Avatar
Yes, my mistake, its a PIC12F683. Thanks.
Well the program flow is pretty simple.
I am not a programming noob, just a PIC noob.
So, I don't mind using C or ASM, its just finding a clear example has been a challenge so far.
Thanks for your pointers.
Audio
Old 18th September 2005, 03:19 PM   #19
Russ White's Avatar
Default Development approach
The program would be simple
1) Read 8bit from ADC to correspond to the voltage divider of the pot.
2) Apply the value to the volume control on both channels.
Here is some lame pseudo code
main() {
while(true) // loop forever
int potValue = readADC(potPin);
setVolume(potValue);
wait(100);// wait 100ms
Audio
Old 18th September 2005, 06:57 PM   #20
saltnpeppah is offline saltnpeppah  India
Hi Russ,
If you could post here the bus speed of the PGA2311; mebbe i can have a look see...
~M.
Digitally controlled preamp/headphone ampHide this!Advertise here!
