I looked over the spec. When you put windings in parallel this does not change the ratio of turns primary to secondary therefore the impedance transform is the same for a single winding or all three in parallel.
Also putting them in series will result in the impedance scaling as the square of the number of turns so that doubling the turns in series will result in 4 times the reflected impedance at the output.
etc..
Kevin
etc..
Kevin
You are correct!I looked over the spec. When you put windings in parallel this does not change the ratio of turns primary to secondary therefore the impedance transform is the same for a single winding or all three in parallel.
http://www.sowter.co.uk/specs/8665.htm
I only understood what you were saying after looking at the Sowter specs. Each winding has it's own turns ratio.
Next to an ecc99 for scale.
Hi Bas,
Have you measured the leakage inductance, interwinding capacitance, and primary inductance of the transformer? What is the operating flux density and how far is it from core saturation?
How is the square wave response at say 10kHz, this would give us a clue as to how many and how well behaved any ultrasonic resonances might be.
Kevin
Kevin
Hi Bas,
I would be happy to take a look at it sometime shortly after the new year. Contact me via the link in my website and we can set something up..
Regards, Kevin
www.kta-hifi.net
Regards, Kevin
www.kta-hifi.net
No not dead at all. I just have to send the transformers to Kevin. But am broke at the moment..Just wondering, is the groupbuy dead, or were the measurements to help gauge interest?
The measurements and evaluation are to ensure that the transformer is worthy of a group buy.
- Headphone Systems
- Aikido as a headphone amplifier (Output transformer groupbuy)
