Tiny Headphone Amps! - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 3rd August 2005, 02:06 AM   #11
maxw is offline maxw  United Kingdom
maxw's Avatar
Originally posted by Relax
Where can I find the output specs for the cMoy on Tangents web page? Does anyone know it off hand?
Depends on what opamp you use. You will find it in the datasheet of the opamp you choose. It doesn't matter anyway though
Old 3rd August 2005, 02:14 AM   #12
Relax is offline Relax  United States
How doe sit not matter? hehe I am thoroughly confused...
Old 3rd August 2005, 02:21 AM   #13
BTW I am using the dual opa132 or OPA2132 by Burr-Brown. I can't make any sense of that datasheet either! Will the cMoy drive my 64 ohm Behringers well without exceeding 100mv max?
Old 3rd August 2005, 02:30 AM   #14
maxw's Avatar
Yes it will drive them fine, dont worry about exceeding 100mv. You will probably not be able to have them over your ears at that output anyway, that is why it doesn't matter. I've never heard of anyone damaging headphones by over powering them.
Old 4th August 2005, 02:35 AM   #15
Works great!
Except its only in one channel, the right to be exact, that I hear anything. The sound coming from the right is loud and pretty clean for awhile until its too loud, but I hear nothing form the left! Whats wrong with me? I looked at the soder and everything looks good, resistors are fine, caps, well, I don't know how to test those yet. could having the LED not in do this? ANY help would be greatly appreciated. Its not the amp either, I switched it out with a new one and same problem. Thanks for your time in advance.
Old 4th August 2005, 05:45 AM   #16
PRR is offline PRR  United States
PRR's Avatar
The dead-simple Cmoy uses a 9V battery and an ordinary opamp chip.
Therefore the maximum output voltage is 4.5V peak, and really only 3V peak 2V RMS in hi-Z loads.
The maximum output current is 20mA to 60mA peak depending on the chip used.
I once prepared a chart showing estimated maximum power for many different headphone amplifiers. Cmoy-like amps plot like curve "b", with 10mW-20mW from 32 to 300 ohms. Three 9V batteries with a high-current opamp chip will plot near line "d", 300mW-600mW into common headphone impedances. Two 9V battery Cmoys are popular for hi-Z phones and fall somewhere between curves "b" and "d".
For comparison, the "*" dots are rated power for a wide variety of headphones. Curve "e" is my suggestion for a "universal" headphone driver, one that will put ample power into any common headphone without mush risk of gross over-drive.
> 64 ohm Behringer HPX2000, which are 100mv max.
No, the HPX2000 is rated 100 milli WATTS, not milli Volts. Makes a difference.
In 64 ohms, 100mW is 2.5 Volts RMS, or 7V peak-peak, which is not a bad match for a 9V battery with some losses in the chip.
Actually, 100mW is not high; some similar phones are rated 3,000mW. With speech/music signals, you can probably run transient peaks 10 times higher than the thermal rating. In fact I'm sure this headphone is made to plug into B-ringer mixers that run +/-15V on the headphone-amp with about 30 ohm series resistance, almost 7VRMS and 700mW of transient power peaks.
Do the B-ringer HPX2K need big power? The specs say "110dB@1KHz" which, by itself, is utterly meaningless. It is traditional to measure headphones in dB SPL at 1 mW. But 110dB SPL at 1mW is absurdly high. I suspect they mean 110dB SPL at 100mW, the rated power. With a 9V Cmoy you would get about 103dB SPL peaks, say 88dB SPL average music level at the edge of clipping. Probably ample for most users.
This is very stupid, but I have many burnt-up headphones. Some come from the Student Labs: I hate to think how much ear-damage those kids have. And personally I have left headphones in a PA system but off my head, and found them blown after the show.
No.
One channel good, one channel bad, means you have a mistake. Take it out in the bright summer sun and check the solder joints, part values, and the what-goes-to-what again. Don't overlook your input and output jacks. Check jack pinout, some are strange. If you used the low-price P-sonic stereo volume control, note that it has a very unexpected pinout.
OPA2132 datasheet, page 6, bottom, output voltage versus current. You have to make some sly guesses and know some about how this chip will clip, but for a single 9V battery I read it as 30mA 2V peak, or 28 milliWatts in 64 ohms.
Old 4th August 2005, 03:40 PM   #17
Thank you very much good sir! You seem to have quite the handle on things, and your help is greatly appreciated. I will continue closely checking my amp and see whats wrong. The hopefully get back to you!
DIY headphone amps - Gilmore? seroxatmad Headphone Systems 1 26th December 2006 06:33 PM
Tiny amps (SSM2211, LM4871, TPA0211) sync40 Chip Amps 4 5th November 2005 03:18 PM
Tiny Headphone Amps! Relax Headphone Systems 4 2nd August 2005 10:03 AM
any good tiny tiny tweeters? THOR Multi-Way 18 28th June 2004 07:42 AM
Copyright 1999-2017 diyAudio
