Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 27th May 2005, 02:08 PM   #21
Russ White's Avatar
Send a message via Yahoo to Russ White
higher available current and lower impedance to gnd are two reasons I can thinks of. Also no quiescent current draw for virtual ground. its a "real" ground.
Old 27th May 2005, 04:52 PM   #22
If your not worried about one of the batteries getting discharged faster than the other i can't se any reason to have the 2426 (i maybe wrong)
Old 27th May 2005, 05:14 PM   #23
00940 is offline 00940  Belgium
http://tangentsoft.net/elec/vgrounds.html
The designer of the pimeta explains at the beginning why he doesn't trust two batteries to discharge equally. The main concern is that when batteries near zero, which coud happen if you let the amp on with music playing too long (getting asleep, leaving the room, and so on), DC offset could go through the roof and destroy the headphones. There are some posts about that on headwize.
Ben.
Old 27th May 2005, 06:43 PM   #24
Lovan is offline Lovan  Sweden
Lovan's Avatar
Send a message via ICQ to Lovan
Yes DC offset is a big problem but only if one rail is A LOt higher voltage-vise i.e. one rail is disconnected. I have found that the effekt is not killing if your using a high impedance headphone(300ohm).
The dc output is about one rail at worst.
I think itīs still usable but with cauton. Somehow you have to monitor the batteries status.
If your using big sealed lead-acid batteries(4-7 Ah) the dc-offset is not a really big problem either. The amp draws about 40mA per batteri. Thatīs stereo. So with the 4Ah batteries you still have 100 hours use without any problem.
Caution though, my experience is limited to high impedance phones. But if DC is a problem you can use output caps.
An idea for a 6N7 headphone amp Bitrex Headphone Systems 3 5th July 2009 11:09 PM
TSHA.. A very simple Headphone Amp idea.. Dxvideo Headphone Systems 15 1st February 2009 07:04 PM
Idea for an ECL82 PP headphone amp. Shoog Headphone Systems 19 14th May 2007 07:34 AM
Hypex headphone idea khundude2012 Headphone Systems 1 13th September 2006 09:50 PM
OTL 6L6 headphone amp-idea+need help trespasser_guy Headphone Systems 16 25th March 2003 01:26 PM
Copyright Đ1999-2013 diyAudio
