Tube Headphone Amp Troubleshooting Help - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 15th April 2005, 04:33 PM   #11
diyAudio Moderator Emeritus
Bas Horneman's Avatar
The first stage should be ok..drawing 4mA roughly
I=V/R
0,004A=3V/750R
the second stage is running a whopping 29mA?
0,029A=6,5V/220R
must get blistering hot R5????..or my calcs are wrong......
so something is wrong with the second stage because it should be drawing around 9mA (0,009A=2V/220R
the first stage is supposed to draw 1,3mA
Old 15th April 2005, 04:45 PM   #12
Yeah, I've double checked R3 & R5 and measure with the Multimeter. I'll check again when I get home. I've tripled checked all the wiring but I'll do that again as well.
Would increasing R5 make the voltage go down? Sorry, I'm such a newbie I have to confess I don't understand what drives the voltage at that point in the circuit.
Thanks.
Old 15th April 2005, 04:56 PM   #13
Ooh...I don't fully understand it either..a bigger resistor will allow less current to pass..that is what we are looking for..the voltage across that is of lesser importance ..for example..if you put a 750R resistor and the voltage goes up to 12 volts the current will be 16mA..better..but still too high...if you have 750R resistor and voltage remains 6,5V...you're in ballpark country 8,7mA
I don't understand why so much current is drawn though???
Old 16th April 2005, 09:36 PM   #14
OK. Problem solved. Turned out my 220 cathode resistor was really 220K!! I apologize. But, in my defense, this was the one part I purchased at Rat Shack and the package did say 220 (I kept the packing). Someone must have re-stapled into the wrong package. Further, this was also the first time I used a digital multimeter and when I checked before installing and during troubleshooting, I never noticed the little "K" in the corner of the display. In fact, it was only when I pulled out my analog meter that I noticed something must be wrong as there was no reading in the "1X" range.
I appreciate everyone's help and promise to return the favor as best I can on my way up the learning curve.
Old 16th April 2005, 09:41 PM   #15
Great! Good the hear.
So the problem was the exact opposite..too little current
6,5V/220 000R = 0, 03mA
Troubleshooting First Tube Project tjotto1 Tubes / Valves 15 26th March 2012 04:08 AM
Headphone amp with tube PS Phergus_25 Headphone Systems 22 20th April 2007 03:12 AM
Octal tube as headphone amp output tube yagoolar Headphone Systems 6 25th November 2006 10:11 PM
Tube troubleshooting question woody Tubes / Valves 1 28th March 2005 09:19 PM
Troubleshooting Problem in Tube Preamp Audiofng Tubes / Valves 3 14th February 2003 12:12 AM
Copyright 1999-2017 diyAudio
