Headphone Systems Everything to do with Headphones
mj headphone amp
mj headphone amp
Old 28th March 2005, 06:10 PM   #1
tubedude63 is offline tubedude63  United States
tubedude63's Avatar
Question mj headphone amp
i am building a morgan jones head phone amp ams would like to know if two inch spacing between tubes is ok
turn up the power till you get smoke then back it off a bit
Old 28th March 2005, 09:08 PM   #2
PRR is offline PRR  United States
PRR's Avatar
You can mount them so close you can't get a finger between. No problem.
But that's from the bad old days when we stuffed too many tubes on too-small chassis, and suffered the heat. I remember TV sets where it was tough to grab a tube: there was actually a special tool for this.
Two inch spacing on a 3-tube amp seems much more sane to me.
Old 29th March 2005, 01:50 AM   #3
PRR's Avatar
This is how IBM used to jam tubes together:
Old 29th March 2005, 05:17 AM   #4
Stixx is offline Stixx  Germany
Stixx's Avatar
Default spacing
don't forget that you have to wire those tubes up, and then you'll appreciate a little more space.
Exactly right now I'm building an MJ also, and my tubes are spaced apart by about 2 inches......only the EZ81 rectifier that I'm using is a little further away from the trio....
rgds,
Oliver
Old 29th March 2005, 02:15 PM   #5
tubedude63's Avatar
thanks all i was worried about heat
Old 30th March 2005, 07:01 PM   #6
runeight is offline runeight  United States
Gentlemen, are you building the MJ or the CJ?
Old 31st March 2005, 05:29 AM   #7
Stixx's Avatar
Alex,
I'm building the MJ with a slightly different psu. Once it's finished I will post on headwize....
Oliver
PS I've seen all your schematics.....
Old 31st March 2005, 05:43 AM   #8
Stixx's Avatar
while we are at it.....
this is the schematic how I'm building the MJ...
Old 31st March 2005, 08:58 AM   #9
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Rather than using a full silicon bridge rectiifier plus EZ81, why not use the EZ81 as part of the bridge and a pair of silicon diodes as the other part? This will give much cleaner switching and prevent the mains transformer from ringing as well as being cheaper and simpler.
Also, do have a look at the various modifications to the original circuit - the addition of variable feedback and optimisation of the anode resistor on the upper valve makes a significant difference.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 31st March 2005, 02:13 PM   #10
Stixx's Avatar
EC8010,
thanks for the input....I've seen both ways of building this "graetz bridge" sort of thing, but didn't know which is better, so I'll happily get silicon diodes (the bridge I have lying about) and do as you suggested.
I'm well aware of the other version of this schematic, but since I'm going to use high Z headphones (Senn HD600) I might be better off with no NFB.......so I have learned.
But it will be easy to try the optimizations also.....
Oliver
mj headphone ampHide this!Advertise here!
Another DAC + Headphone amp ghetto Digital Source 14 10th July 2008 04:02 PM
Using a headphone amp as a pre-amp? Basalt Solid State 4 19th November 2007 09:55 AM
ESL Headphone X-former bjackson Planars & Exotics 5 19th September 2005 03:45 AM
Headphone amp audioPT Headphone Systems 3 20th September 2004 10:17 PM
Zen v4 headphone amp Rob M Headphone Systems 11 21st May 2003 12:58 AM
Copyright ©1999-2017 diyAudio
