Headphone Systems Everything to do with Headphones
Headphone Output to GC amp
Old 29th March 2005, 12:08 PM   #11
mourip is offline mourip  United States
mourip's Avatar
Originally posted by StalfoS
Thanks for the suggestions all, I still have not decided what I will go with. I wanted to design my amp with simplicity in mind, however it occured to me that not having a headphone jack will be a problem.
If I were to include simple headphone amp circuit what would be the best way to power it? Off of the rails or with a seperate transformer?
Simply putting a voltage divider on the output is looking more and morea apealing...
It will only cost you a few dollars to try it out. You could wire it up without drilling for the jack just to see if the sound makes you happy or not.
Some things that seem like they would be important in theory are inconsequential in practice. For me audio is more like cooking than science. The bottom line will always be if you like the sound. Theory is only useful for pointing you in a direction where that is more likely to happen...
Good luck,
Paul
Headphone Output to GC ampHide this!Advertise here!
4 Pin Amp output to 3 Pin headphone jack? StrayS2k Headphone Systems 3 17th February 2009 04:46 PM
Aikidos Headphone with Output Transformers? wonsup Headphone Systems 4 15th April 2008 05:34 PM
Add headphone output to preamp whitelabrat Headphone Systems 2 24th January 2008 07:36 PM
How to connect 62 ohm headphone to 8 ohm output Sunsun22 Headphone Systems 15 16th June 2007 01:29 PM
What output Z for headphone amp? jeffreyj Headphone Systems 29 13th August 2003 10:28 PM
