Headphone Systems Everything to do with Headphones
Safety when testing headphone amp  for muso's
Old 19th March 2005, 07:59 AM   #1
loonatron is offline loonatron  Australia
Default Safety when testing headphone amp for muso's
At work yesterday, I had to test headphones at a really loud level, to check a supposedly distorting headphone amplifier. As I half expected, the distortion was within the performance that you would expect... it only distorts at levels above what is a safe listening level. I felt really anxious afterwards, as I was testing the amplifier by listening through headphones (two different types, with different impedances, both worked fine) and almost blasted my head off.
What is a safer way to test them? Should I use a dummy load and check test tones with a CRO, and compare the results with the spec sheet? (which may not always be available)
many thanks, from Steve
Old 19th March 2005, 09:00 AM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
It appears you already tested them with a dummy load.
Old 19th March 2005, 10:33 AM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Foam earplugs. Or mic them up and run through the main desk.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 19th March 2005, 11:14 AM   #4
yes, but I was looking for some useful advice here, more like what pinkmouse had to say (I see your humor!)
Old 19th March 2005, 11:37 AM   #5
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Seriously,NEVER test headphone amps with headphones on your ears!
If something went wrong,and the amp went into a full-power oscillation or something wierd,that LOUD screeching sound might be the last thing you ever hear.
Use a dummyload,small speaker,or just leave the headphones sittin on the desk,you'll still hear them okay... Just NOT on your ears.
(A very useful tip I learned the hard way while working on a 1Wpc tube headphone amp.)
Old 19th March 2005, 08:56 PM   #6
Thanks, I won't be that silly again! :
This is what I will do next time...
1) make a dummy (resistive) load
2) put a test tone through amp
3) measure output on CRO
4) when output distorts, measure output with AC voltmeter, calculate power output, compare with specifications. Tell those who reported it faulty that it works within the design limitations. (if that is the case)
I will also put a pair of headphones (via an attenuator) in paralell with the dummy load, for an objective sound quality test. (That is what most of us identify with!)
When I did the att'n: 'dangerous' testing I actually found that with some songs on the CD (a Daft Punk CD) the bass just deteriorated completely, even though the volume wasn't really that loud. The only way I could think of checking that this was normal performance for this amplifier was to check it against another identical unit. Both performed the same. This is where it becomes subjective, as I'm sure that the manufacturer's specs are only going to specify the power output at the frequency at which the power output is the highest. (for marketing reasons)
Has anyone got any more suggestions?
Many thanks, from Steve
Old 19th March 2005, 09:02 PM   #7
pinkmouse's Avatar
Just play around with the patch panel, tell the muso you swapped the channels to a good one, but don't actually change anything. That fixes the problem 95% of the time...
Old 20th March 2005, 12:22 AM   #8
Good idea! I like that one! But the headphone amp was sent back to me for 'repair' from a live gig.
Old 20th March 2005, 04:07 AM   #9
sam9 is offline sam9  United States
sam9's Avatar
Here's something I'm going to order from digikey along with regular stuff.
http://rocky.digikey.com/WebLib/Pana...A%20Series.pdf
I want to see if a headphone amp can drive them. They might be an answer to safely listening to headphones amps. I've idea what they will sound like. They are cheap and maybe I'll end up with "minim-Magnepans" beside my PC.
Safety when testing headphone amp  for muso'sHide this!Advertise here!
Safety First pacificblue Chip Amps 11 31st July 2009 06:59 AM
safety fuse Tubesin Tubes / Valves 0 28th January 2006 09:55 AM
83 safety rules Tomatito Tubes / Valves 5 17th May 2003 11:17 PM
Copyright ©1999-2017 diyAudio
