Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 9th March 2005, 02:44 PM   #51
baggystevo82's Avatar
Send a message via MSN to baggystevo82
Originally posted by richwalters
Also anode load in first stage is nice and low, again ideal.
Hehe, just been working on a slightly modified first stage with only one led biasing, and a 15k load. This reduces distortion of the first stage at 5v p-p output to around 0.03% THD, down from over 0.06% that it was in this part of the circuit earlier (with 2led's biasing and a 10k load). Is this right to do?
Steve
Old 9th March 2005, 03:11 PM   #52
richwalters's Avatar
You could be getting close to the cut off curve.....if you swapped for another 6N1P perhaps the thd results won't be so favorable. Give it a whirl....but consider tolerance and spread in the curves......I will have to look up this tube.......
richj
Old 9th March 2005, 03:19 PM   #53
ok I'm down to overall amp THD of 0.017% at 10mA ignoring the 2nd harmonic now. Still around 0.7% with though I guess this is down to the Cathode follower. Hopefully the 2nd harmonic won't be so important...
Steve
Old 26th March 2005, 04:20 PM   #54
Back again!!! More rethinking going on....
I think I'll still stick with the LED biasing, but moving accross to transformer coupled output now I think...
Just a short question to start with though, as a triode, EL84 maximum plate voltage = 300v. Does this mean that I can use a higher b+ (like 450-500v) so long as the grid doesn't go negative enough to exceed this rating?
Steve
Old 26th March 2005, 06:23 PM   #55
SY's Avatar
The max voltage is plate-to-cathode. So it's probably a good idea not to go over 300 even with cathode biasing.
If there's a sucker born every minute, where do the rest of them come from?
Old 16th April 2005, 11:50 AM   #56
I've just find this page:
http://www.turneraudio.com.au/htmlwe...evisedst70.htm
looking at the output stage cathode bias I've seen the zener diode string across each cathode RC network. Its purpose is to limit the rise of voltage in the cathode bypass caps when the amp works hard in class AB. Can this be worthwhile for standard cathode bias?
Mark
Old 16th April 2005, 12:55 PM   #57
Do the LEDs dig to the music ?
<WTA>Tube biased by LED arwan_zoel Tubes / Valves 1 24th October 2008 02:33 PM
12AU7/EL84 Headphone Amp sorenj07 Headphone Systems 8 5th February 2008 04:44 PM
The Importance of Being Biased Nelson Pass Pass Labs 74 26th July 2007 01:58 PM
OLT Headphone amp useing two EL84's & a 12ax7? ak_47_boy Headphone Systems 3 24th December 2006 07:58 AM
#19 biased class A Joel Tubes / Valves 33 20th December 2002 05:38 PM
Copyright ©1999-2013 diyAudio
