LED biased EL84 headphone amp - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 27th December 2004, 06:01 PM   #21
SY's Avatar
First rule of diy audio design: start with the parts you already have!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th December 2004, 06:17 PM   #22
baggystevo82's Avatar
Send a message via MSN to baggystevo82
Especially when you're a student trying to scrape together next months rent! hehe
Steve
Old 27th December 2004, 07:19 PM   #23
IR LED's
Any thoughts on these? Apparently they take 100mA continuous and have a forward drop of around 1.35v, could be useful?
Steve
Old 27th December 2004, 07:37 PM   #24
SY's Avatar
Might be. I looked at Vishay's data sheet and from eyeballing the If vs Vf graph, it looks like the impedance is around 4 ohms or so at 50 ma. And the price is sure right.
Actually, in your application, the impedance is not really an issue, so these would certainly be worth giving a spin.
Old 27th December 2004, 07:50 PM   #25
I saw that graph too, thought it was fairly reasonable up to 100mA. Shame you'd need so many to bias a big output stage though I was thinking maybe it can handle so much current partly because of the lower drop, and partly because it radiates infra-red?
I was thinking of using them on a plain common cathod 6n1p input stage for this amp, biasing with one red and one IR led, giving around 3V bias. With a 15k load resistor the operating point sits at about 6mA so unfortunately that 100mA capability wouldn't be put to much use.
Steve
Old 27th December 2004, 08:56 PM   #26
OK, here's what I have now, all LED's being cheap red ones, though I'm not sure about the LED's on the 6n1p. I can't find any information about when grid current starts, so I think the bias of 3 - 3.4v is OK.
Steve
Old 27th December 2004, 09:17 PM   #27
SY's Avatar
Looks good, and with all those LEDs going, you'll be able to read a book with the room lights off.
Old 27th December 2004, 10:23 PM   #28
Hello again! More questions unfortunately...
Been playing with this in PSU designer, as it's shown here it says the transformer is 380V RMS, I think this means I need a 190-0-190 transformer but I'm not certain. Once it settles down ripple comes out at 0.16mV which I guess is fine, I hope.
Steve
Old 27th December 2004, 10:41 PM   #29
SY's Avatar
With a choke input supply, you'll need more like 380-0-380. Since the dynamic regulation requirements are minimal, I'd be more inclined toward a C-input supply, a lower voltage transformer, and (if I were feeling ambitious) a Maida-style regulator.
Old 28th December 2004, 06:53 PM   #30
Hello, This is the layout I've come up with now. I wish I had a better camera, but hopefully the general idea should be clearish. It all just about fits onto a piece of A4 which I'm happy with. Is the case of a normal electrolytic tied to the -ve or +ve terminal? I think the JJ's are completely insulated, but I don't think the ones I intend to use as output are, and this could be a danger if it's the +ve that's connected to it as they will be outside the case (probably).
Steve
<WTA>Tube biased by LED arwan_zoel Tubes / Valves 1 24th October 2008 03:33 PM
12AU7/EL84 Headphone Amp sorenj07 Headphone Systems 8 5th February 2008 05:44 PM
The Importance of Being Biased Nelson Pass Pass Labs 74 26th July 2007 02:58 PM
OLT Headphone amp useing two EL84's & a 12ax7? ak_47_boy Headphone Systems 3 24th December 2006 08:58 AM
#19 biased class A Joel Tubes / Valves 33 20th December 2002 06:38 PM
Copyright 1999-2017 diyAudio
