Go Back   Home > Forums > Amplifiers > Headphone Systems
Headphone Systems Everything to do with Headphones
Old 30th September 2004, 04:51 PM   #1
ble0t is offline ble0t  United States
ble0t's Avatar
Default Headphone Switch Circuit
I'm currently working on a pre-amp with built in headphone amplifier and I would like to mute the output of the pre-amp if headphones are plugged in. The headphone jack has a single switch in it (link here) that I would like to use to send a signal to my PIC to mute the output. Attached is an image of my intended circuit.
Would this work? The PIC has an ADC I would be using, so that is not an issue.
Thanks, and don't be too harsh...I'm only a newbie
EDIT: The little unconnected wire there is supposed to represent a switch...crude I know
gravity always wins
Old 30th September 2004, 08:22 PM   #2
ble0t's Avatar
I don't mean to be pushy, but here's a little thread bump
Anyone have any thoughts on this at all?
gravity always wins
Old 30th September 2004, 09:21 PM   #3
sam9 is offline sam9  United States
sam9's Avatar
I don't know much (anything) about PIC but I assume that the mute works by applying a voltage within a specified range to a pin. If that's right the key would be to create voltage reference on that range. I don't know how fussy a PIC device is but assuming you already have a clean regulated PS, wouldn't a simple means be to just take a DC feed off the power supply and drop it to the control voltage by means of a zener diode. Then just wire your swith in series with the control voltage.
Alternative: Use the switch to control a DPDT reed relay that switches the preamp output signal either to the headphone amp input or to the preamp output jack. A good reed relay is very quite and should do no harm to the signal. It has the advantage that you can locate where it keeps the signal path short but the contol switch can be where it is convenient. The wire carring the DC control volage can be on any reasonable length and run most anywhere.
Old 30th September 2004, 09:27 PM   #4
Swedish Chef's Avatar
You are using an NPN-transistor as a "high side" switch here which I would avoid. Use a PNP transistor instead such as BC327. Also, you need a "pull-down" resistor from the emitter (OUT_PIC) to ground to make this circuit work. Something in the 1-100kohm range would work fine. Most microcontrollers have internal pull-ups/downs that can be activated. It was many years since I used the PIC's but IIRC they have internal pull-ups on some ports.
If you want to make this circuit even simpler you could emit the transistor and just use a pull-up resistor from the headphone switch to VCC although you have to watch out for ESD. It's up to you.
/Magnus
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Old 30th September 2004, 09:55 PM   #5
johnnyx is offline johnnyx  United Kingdom
Default Re: Headphone Switch Circuit
Is there a relay on the main output to do the switching? How would the output be muted? Is there a "power-on delay" to prevent thumps at switch-on?
You don't have to go via the PIC. Whatever mutes and unmutes the output can be arranged so that the output is on when power is ok AND the headphones are unplugged, otherwise it's off.
Hope this helps.
Old 1st October 2004, 05:20 AM   #6
ble0t's Avatar
Yes, there is going to be a relay on the main output. As for controlling the possible thump from this, I'm using a 'soft mute' circuit design that should prevent it.
Thanks for all the advice...I'm hoping to pick up a few parts to test with next week. If all goes well, I'll report back here...perhaps someone else can use this in the future as well.
gravity always wins
Old 11th December 2004, 10:07 PM   #7
eibwen is offline eibwen  United States
Default how'd this work?
Hello, just wondering if this worked well or not?
I would like to make something like it.
Actually i'd like to make a 5.1 version, so that when i plug headphones in it turns off all the surround sound speakers, and feeds the left and right to the headphones. Altho its not really needed to do that, but I would like it so that if i forget to go into my speaker configuation thingy for my audio card, the center, sub, rear speakers would be silent no matter what.
Well: so for 5.1 i would need a special chip to control it, right?
That would be hard to find i would think, so i might just make it like yours, and have to remember to go to my speaker config all the time (which i would have to do anyways, otherwise i would hear what was processed to go to the left and right, so much less vocal usually)
Ok well, the big question, how much did it cost in the end?
-Greg
Old 24th March 2008, 06:33 AM   #8
dfdye is offline dfdye  United States
dfdye's Avatar
Wow, no love for this in a while! And no resolution to boot!
I'm running into the same question as to how to mute a circuit (specifically an LM1876) by pulling up the mute pin from ground to 2.5V. via opening the switch on the headphone jack. I can easily get the 2.5V to a transistor that can be controlled to drive the mute pin, but I can't easily figure out how to control the transistor with what would normally be an audio signal.
Any new thoughts?
. . . . . Of course I can always add a manual mute switch, but where is the fun in that?!?!?
Headphone amp circuit question. Artie Headphone Systems 5 15th April 2009 07:32 PM
Headphone amp circuit for preamp use. marchel Solid State 2 6th February 2008 10:11 PM
I'm looking for a LM3875 headphone circuit serenella Headphone Systems 5 19th November 2007 06:00 PM
bright switch to bias circuit? PRNDL Tubes / Valves 3 3rd November 2006 08:43 PM
can i use this circuit as headphone amp? GazzaFloyd Headphone Systems 1 28th June 2004 09:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
